Question about Compaq Presario 2575US Notebook
Installed memory I went to crucial.com and scanned my laptop and it said that i could upgrade my memory to 512mb on 2 slots so when i installed it and turn my computer on it wouldnt restart how do i get it to recognize the memory bc i put the old memory back and it stil works but with the new it turns the fans on but no picture or signs of the laptop being on PLEASE help
    Genius:
  • 2,028 Answers
Make sure the new memory is the same as the old. Memory has a set frequency, this frequency matches the processor, so you can't just grab any memory and throw it in the machine and expect it to work. Memory will be rated as either PC or mhz, ie... PC100, PC133, PC2100, PC2600, PC4200, PC5300, 100mhz, 133mhz, 266mhz, 333mhz. These are some of the most common. Your memory should have a tag that tells what it is. If the old memory doesn't, give me the make and model of the machine and I can tell you what it is. If the old and new are the same, then one of the new may be bad, it happens.
Posted on Jul 03, 2008
I need L4000-H memory 512 or 256 how much????
go to crucial.com and check the "upgrade" for it http://www.crucial.com/store/listparts.aspx?model=L4000H%20Series&Cat=RAM
notebook.gif Your L4000H Series System SpecsSystem specs as shipped by the manufacturer.
Scan your system to view your specific system configuration. Memory:DDR PC2700 icon_detail.gif
Memory Type: DDR PC2700, DDR (non-ECC)
Maximum Memory: 640 or 768MB
Slots: 1
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.*
May 20, 2011 | Lifetime ASUS L4000H Replacement Laptop...
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
Customer has * Installed Size 1024 MB * Technology DDR II SDRAM how many gigs is this all ready? What is it equal too 1gb, 512, etc........ . what type of memory should i use ............ its a...
256MB = .25GB
512MB = .5GB
768MB = .75GB
1024MB = 1GB
Your HP Mini takes this type of memory:
DDR2 PC2-5300 • CL=5 • Unbuffered • NON-ECC • DDR2-667 • 1.8V • 256Meg x 64
You can find the memory type for your computer here:
http://www.crucial.com/store/listparts.aspx?model=HP%20Mini%201151NR
Oct 19, 2009 | Computers & Internet
COMPAQ LAPTOP MAMORY EXTEND
This laptop has 2 slots
So maximum memory supported is 1GB.
If you install more memory there is a high probability it will not be recognised.
You can get more information and order memory from the link below:
http://www.crucial.com/store/listparts.aspx?model=Presario%20M2000%20Series
Jun 08, 2009 | Compaq Presario M2000 Notebook
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
Can't upgrade memory
According to the user manual for your laptop, it can only support pc-100 memory. If your going to upgrade your memory just make sure you use pc-100 and also the max amount of memory is 256mb in each slot so you would be maxed out at 512MB.
You can verify the info from this link from Dell:
http://support.dell.com/support/edocs/systems/latc600/en/ug/features.htm
May 23, 2009 | Dell Computers & Internet
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
RAM upgrade is not working
A 200-pin PC-3200 SODIMM should work in your machine but it will clock down to 333MHz. Your computer has 2 slots with a max of 512MB per slot (1GB total system memory). For maximum compatibility you should stick with a low density (16-chip - double-sided) PC2700 DDR-333 SODIMM with a CL of 2.5. Link below to see an example:
http://crucial.com/store/listparts.aspx?model=Pavilion%20ze4300%20Series
-E
Dec 25, 2008 | HP Pavilion ze4365us Notebook
Memory upgrade
Go to http://www.crucial.com/ and click "Scan My System". Click on "Run" when prompted. It will tell you what you have, number of empty slots, what kind, and make suggestions to upgrade. It works well.
Nov 21, 2008 | Dell Latitude C640 Notebook
Compaq Presario 2575US Notebook Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
