Question about Shop Vac Vacuums
I have a Sears #113.177331 wet'dry shop vac. I have the motor out and want to know how to change the brushes. Thanks...Steve
  • steve16428 Jul 04, 2008
    Do I have to remove the fan blade on top of the shaft or the T-washer on the bottom of the shaft? I know about pressing things on and off but space is extremely limited. Any tips yet??? I cleaned the commutator and tried the unit again but apparently it is the brushes that need replaced.
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
SOURCE: Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Posted on Sep 09, 2009
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
  • 10319 Answers
SOURCE: Where can I fet parts for a Genie SV300Q wet/dry
Depending on what parts are needed Home Depot for instance carries parts for these
Posted on Apr 13, 2010
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I was using the shopvac and it just quit. (changed filter, still
The brushes that make contact with the motor's armature need to be cleaned. If you get into the motor and find that the armature is scored or burnt then you'll have to replace the motor.
Oct 06, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
3.0 h.p. wet/dry vac
Check the motor brushes, either worn down or dust is keeping one of them from laying on the armature. The other would be a bad motor.
Jan 13, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Vacuums Logo
141 people viewed this question
Top Shop Vac Vacuums Experts
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
