LG air conditioner problem - power light flashes on LS-J0962NL
Hi, I have a split system LG air conditioner (Model no LS-J0962NL) that is playing up.  It works fine sometimes, but other times will shut off after a minute or 2 leaving just the green power LED flashing.  I had it serviced the other day and it worked fine (typical!), but is failing again now.  If I turn it on cool, the compressor indicators light up a couple of times and then go out, the outside fan doesn't spin (although it can turn freely), and then the inside fan stops and the light flashes.  The rest of the display goes blank, ie no error code.  Any ideas?  Thanks, J.
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 340 Answers
SOURCE: Ruud achiever 9 outside fan not working
u need fan motor
Posted on Jul 11, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Lg aircon splitape p/no:3854A90006F how much the price
Hi.
The price for the model listed is not available. Please select a different model from LG website: LG Air Conditioners
Feb 15, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
Please help i got a LG r12awn split and the heating light flashes twice followed by one flash on the cooling, ive read through the manual and cant find any thing about it
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor. Thanks.
Feb 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Lg spilt system turns of after 5 mins green light flashes
You need to note the pattern of the flashes, short or long flashes etc.
there is a legend that explains all the possible codes.
Example: 3 long flashes 1 short flash, the legend will say something like hi pressure safety switch
or low pressure safety switch , this could mean dirty coils, inside and outdoors, or bad fan motors either location as well, the compressor may be over heating or overloading, or be gong bad. a capacitor may be the culprit, what you can do is see the fuses and airflows good and no coils blocked etc , notice if any motors stop causing the flasing lockout condition.
Dec 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I do not have the manual for my LG LS-D2461HS air conditioner
On your email you have the model down as LSC121PMA - this is not the model I posted my query on, it ws the LG LS-D2461HS, and no my query is not solved.
Dec 13, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
796 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
