Back to:
Tags:
Epson Aculaser C1100 Printer
How to rotate toners
posted by soler on Jul 03, 2008
how to rotate toner cartridge
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 11, 2008
FixYa! (100)
joiner
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how to rotate toners:
I don't want to Accept this solution
Solution #2
posted on Jul 04, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2415 votes
and hello again,
I have responded in your other posts that the printer will automaticallydo so if and when you are replacing or inserting new toner cartridges.
Pls see your other posts here and here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Thank You!
Can you Help with these Printers problems?
epson c1100 keep getting message photoconductor trouble...
When I try to print through the network it says...
Hi, I'm getting a message 'Service Required C0085' can...
Hi! I have a canon (1800) super G3 printer, it reads:...
The printer will not operate and states that "B...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
