Question about Lexmark X1270 All-In-One InkJet Printer
Print spoolers I have a lexmark 1270. It didn't work and one of my daughters tried to fix. Now the computer (Vista) indicates that the print spooler is not there or dependency services are not there. Can it be fixed without reinstalling Vista?
    Master:
  • 788 Answers
In the search bar of the start menu type in "services.msc" without the quote. After hitting Enter you should get the services control panel. Ensure that the print spooler service is started and set to Automatic. If it runs into an error when trying to start it should report what service it causing the problem, ensure that service is also started and set to automatic.
Posted on Jul 03, 2008
I disconected my lexmark printer from my desk top windows me 2000 and try to connect to my lap top windows vista .I have run the disk over and over agaian, but is not connecting please i need assitances thank you my email is esolora@yahoo.co.uk
Posted on Jul 04, 2008
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Lexmark 1270 All In One Printer, Scanner, Fax
I suspect it is because the print buffer in the printer is not being flushed properly and the document is sort of getting hung in limbo between the computer and printer.
the only way to clear cue is either re-start, disconnect the printer from the computer, or turn the printer off. Sometimes you may need to unplug it as well.
Mar 03, 2008 | Lexmark Color JetPrinter Z42 InkJet
Printer stop printing
It could be the Print Spooler service on your computer that's not properly working. Try these steps to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Mar 11, 2012 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
Printer won't print from computer
Try the steps below to clear the print queue and restart your print spooler:
Jan 11, 2012 | Lexmark X5495 All-in-One &USB...
I have a lexmark 1270 ( that's what it says on the printer) and the printer is on, and I go to print and nothing happens...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot the pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
It could also be that the Print Spooler service on your computer has stopped. Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Jul 27, 2011 | Lexmark C533DN InkJet Printer
Printer will not print the ink packages are new but the indicator on print que shows (?) on both black and color indicators. the que shows printer 1 to 3 % progress then stops. thank you for your help
It could be that the print spooler service on your computer has stopped. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 23, 2011 | Lexmark X4650 InkJet Printer
Unable to print doc. Status indicates 'Printing Pls advise
It could be the Print Spooler service on your computer(for Windows). This article in the Lexmark website on How to Restart or Reset the Print Spooler in Windows might help fix the problem.
Mar 21, 2011 | Lexmark X2500 All-In-One Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
