Question about Lenovo 3000 N100 0689 Notebook
NOT GETTING SWITCH ON
MY LENOVO 300 N 100,DONT GET SWITCH ON,I TRIED IT BY APPLYING DIRECT POWER SUPPLY,BY REMOVING BATTERIES.BUT IT STILL NOT GETING ON,I SHOWN IT TO ON TECHNITIAN ,HE SAID MIGHT BE MOTHERBOARD IS DAMAGED,SO WHERE TO REPAIR IT NOW
  • 165 Answers
New Lenovo tower is not doing anything except the fan is running and the power light is blinking.
Check the cable to the monitor and try the monitor on an other computer. If that not works, get in contact with lenovo support, or go to the store you bought it. They should be able to help.
Dec 24, 2014 | Lenovo Computers & Internet
Lenovo tower will not power up. Everything else on same power strip is working. Monitor, copier etc. I tried unplugging it and using a different outlet but still nothing. It was working fine yesterday...
If you tried a differwnt outlet in the strip I would take the tower or power supply out and have it tested at a repair shop. I am leaning towards a power supply fault, but I
have also seen where one of yhe outlets in a strip burns out. Sometimes the power supply has a green light near the power cord. If this is out then it will need replacing.
Dec 05, 2017 | Lenovo Computers & Internet
Lenovo Y550 has been sitting without being used for many months. I tried to power up today with the AC adapter plugged in. It tries to start, the disk drive symbol flashes on for a second of two, and...
The power supply may have an issue. I would leave it charging in the off condition over night and if the battery takes a charge and the system starts up when you turn the laptop on, that will prove the power supply ... that may well recover as the capacitors re form.
Oct 25, 2013 | Lenovo Y550 Notebook
Lenovo 7757 no power and light
IS your laptop getting charge? have you tried with if your charger is providing proper voltage? try with other charger removing battery.
IF stil you face the probelm then there could be motherboard issue.
Aug 06, 2012 | Lenovo Computers & Internet
Lenovo mouse charging
Most of the mouses have a kind of switch and when opened, there are 2 batteries. you can replace them with other rechargeable batteries
May 28, 2012 | Lenovo Wireless Mouse
Passenger side power window inop. Possibly a switch, fuse? Can I fix myself? What parts are required? Thanks
Try removing the door panel, and then feeding direct power to the motor using two wires connected to power (positive) and ground (negative). Connecting the wires one way will make the motor move the window up, and reversing the connection will make the window go down. If the motor works ok when you do this, then you have a wiring or switch issue, likely a switch. If the motor doesn't work with direct power and ground, then you have identified the problem. Good Luck!
Sep 23, 2010 | 1994 Ford Explorer Limited
Brake lights dont work changed bulbs , fuse , and stop light switch any ideas
Check to see if you are getting power to the fuse, Next check the power going to the brake switch. After you check for the power going into each location, and you find the one that's not getting the power, you may have a bad wire, also check to see if the brake switch is set up right to depress when applying brakes.
May 03, 2010 | 1999 Lexus RX 300
PCU turned off itself, I tried to restarted but it dont start. switch button is fine gateway 505gr
check your power cable to make sure power supply is getting power. you may need to replace power supply.
Dec 24, 2009 | Gateway Computers & Internet
Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
Jul 03, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Packard bell notebook geting stuck
My first instinct would be a power supply problem, try reinstalling OS first..
May 11, 2008 | Packard Bell Easy One Silver 2101 Notebook
Lenovo 3000 N100 0689 Notebook Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
