Question about Refrigerators
Hotpoint frige/freezer ff178e. water collects inside bottom of freezer
    President:
  • 1,462 Answers
I assume temperatures ok in which case the water will turn to ice.
problem is a blocked drain, probably with ice. remove the rear panel inside the freezer and clear the drain with hot water till it flows away freely. takes a little patience. if there is excessive build-up of ice on the pipework, then you have a problem with the defrost system
Posted on Jul 04, 2008
I have Hotpoint model CTX18BABKRWW Serial#ZT515963. Water is collecting in frige under two drawers. I cannot find a drain or a drain tray. Sounds like a low hum noise. Frig is cold and freezer is...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Aug 15, 2011 | Hotpoint Refrigerators
Have a GE Frige # TBX18SAXPLWW. Large amounts of water collect on inside, bottom of frige. Back wall wet from frige/freezer temp control locate at upper most rear wall of unit. What could problem be?
When in defrost mode, frost is melted and the water is directed to a tray at the rear bottom of the freezer. A tube is connected to the bottom of the tray so the water is sent down the back of the refer to evaporate at the bottom.
The tube gets clogged with gunk, water backs up and freezes. Then, at the next defrost cycle the water has no place to go except into the refer interior.
Unload the freezer, remove the bottom plastic plate, let the ice melt, unclog the tube, put everything back together and you're good to go!
Aug 08, 2010 | GE Refrigerators
How to replace seal on the freezer door
  • Take food out of freezer
  • Take rack out
  • Take out any ice cube racks
  • Remove ice accumulated in the bottom of the compartment (I used a hammer)
  • Unscrew the back panel inside the freezer compartment
  • You won't be able to remove the panel right away because of the plastic duct is mated to the bottom of the freezer compartment.
  • Lift the panel up to unmate the duct and the bottom, and pull the top end of the panel toward you. Don't pull too hard because there are electrical wires attached to it.
  • Disconnect the wires and remove the panel / duct.
  • I saw an accumulation of ice and a hole.
  • Remove whatever ice you can.
  • Pour boiling water into the hole to remove ice inside the hole.
  • You'll know you've succeeded when water runs easily down the hole.
  • The water should collect underneath the fridge - there is a grille that you can remove (Just pull) and you'll see a pan where the water is collecting.
I just did this so I'm not sure if it will happen again ...
Good luck
Jul 29, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water collects under bottom draws of frige
At the back of the fridge, inside, there should be a drip tray / channel which slopes towards the middle from both sides. At the middle you will find an outlet hole to the rear probably blocked. Clear with match or cocktail stick and the water drains away to an evaporation pad or container [often over the compressor]
Mar 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Hotpoint FZA80 freezer: water leaking
There's a drain hole inside the freezer in the bottom of the back wall ;probably is clogh .Put hot water into it to melt the ice and then blow it with air pressure;keep it clean pouring bleach throught it every 2 or 3 months.
Jul 18, 2009 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Water collecting in bottom of refrig Hotpoint
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
