Question about Whirlpool Duet GHW9150P Front Load Washer
Front loader tub bearing replacement -- worth it?
I just saw your article on the above topic and am wondering whether it is financially worth it to have a repairman replace the bearings (and possibly tub). Friends have had similar problems and ended up buying a new washer. Is this typically a job that is going to run > $300-400?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    It usually runs much higher at a cost of $600 to $1000 if you have a repairmen do it. This job normally takes 2 to 3 hours for a skilled technician, so you will incur additional labor charges. Thats why the cost is so high. If you have a service plan or warranty, this charges would be waived. Even without a warranty, its not a difficult repair if you are mechanically and electrically inclined. However, for the average do-it-yourselfer, I would not recommend it. Its quite involved with disassembling an entire machine to replace one single bearing. Stupid design if you ask me. I hope this helps some. Let me know if you have further questions.
  • Butch May 01, 2013
    I just want to know where to find the bearing
  • 413 Answers
Rear tub runs around $293.00, labor and service charge, around $168.00. Check your owners manual for any limited warranties that may cover the part.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 04, 2008
During spin cycle drum makes loud noise. Sounds like bearings are going out. Can they be lubricated? Or replaced
Depends on what sort of machine it is. (Front or top load)Bearings can be replaced but this will always entail replacement of all the tub seals and in the case of front loaders, almost always , it will need a new drum shaft. The costs to fix can be expensive. To confirm bearing failure, you can see if the tub moves and clunks on the main shaft and the noise will increase as the tub speed increases. Drum bearings usually fail when the tub seal fails or is worn out, allowing water to get into the bearing and wash all the grease out. Brown , black greasy stains under your machine and on the floor is usually a telltale sign as well.
Mar 20, 2017 | Washing Machines
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
My LG makes a rattling noise on spin/rinse cycle. To me it sounds like a roller that is loose on its baring. Any ideas?
Could be bad bearing. Could be broken spyder (holds drum tub to bearing shaft). Could be loose bolt that hold drum axel to bearings(very rarely would that happen). Open door, grab inner tub, try to move it back and forth, in and out. If it moves and outer tub doesn't, then one of the above is the issue. All this is assuming a front loader machine. What's model number?
Feb 20, 2017 | LG Washing Machines
My washer jumps around when spinning. this happens intermittently
if it is a front loader and on a pedestal make sure it is level not just front to back but side to side also. Here are some of the reasons a front loader shakes violently.
1-- not level
2-- unbalanced load... washing 1 item or large comforter
3-- Wrong soap.. using reg detergent instead of HE
4-- bolts mounting mach to pedestal are loose. They are located above the drawer. two for front and two for rear.
5-- Faulty shocks.. requires tech to repair
6-- unhooked springs.. requires tech to diag and repair
7-- rear bearing failure. can be checked by pushing up on top front edge of basket and looking for movement independent of outter tub. Sometimes you can feel a clicking of the bearing moving up and down when you do this. This repair usually costs more than the machine is worth if very old. Ignoring this problem can lead to more damage, water leakage, and possibly fire.
Sep 17, 2011 | LG Washing Machines
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
Where is the rear bearing located so i can grease it
The rear bearing is not accessible to grease. If you have a noisey spin that sounds like it is coming from the bearing it will have to be replaced. Most tub bearings on front loaders are preinstalled with the outer tub assembly. It is a major job to overhaul a front loading machine, requiring outer tub assembly, water seal kit and possibly tub gaskets. If not under a warranty it is not economical to repair.
Feb 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
My Kenmore Front Loader washer machine is making a loud noise during the spin cycle
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Jan 11, 2010 | Kenmore 43042 Front Load Washer
Machine will not empty water, new pump installed today still no joy any ideas
Whether a front loader or a top loader, you are probably missing a sock. My guess being a sock or similar sized article has escaped the tub and is obstructing the water discharge to the pump. How to get to it depends on the top loader/front loader/make/model thing.
Dec 18, 2009 | Washing Machines
Im wondering how to get the bearings out of the drum?
you have to replace the back tub the bearing come built in the tub from the factory there is not any way just to replace just the bearings
Dec 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
408 people viewed this question
Dan Webster
Dan Webster
Sal De
