Your Intrigue is equipped with the 3800 V-6 motor...The motor is mounted transversely...(sideways:) You can trace the spark plug wires from the spark box to each of the 6 plugs...I recommend you use AC platinum tip plugs, verify the gap...should be 45 mm...spark plug gap tools are inexpensive and available at all parts stores...Use thread lubricant...and plug wire tip lubricant...As your mileage is over 80,000 you should also consider replacing the wires too...:)
