Broadband Speed Using an Orange Live Box, download speed 130kbps! BT Engineers checked their end & it registered 5.1Mb. Tried using Wireless & wired PC's with same result! Reset Box loads of times, phoned Orange loads of times. What's doing it?
  • 2 more comments
  • forge2000 Jul 05, 2008
    I've changed the wire to the Live Box & I've changed the Filter. The Live Box has also been replaced!
    Cable to Live Box, Live Box itself & the Line Filter, have all been changed.
  • forge2000 Jul 08, 2008
    BT checked the line here & it showed 5.1 mb. Thus state the fault is not theirs.
  • pugdog05 May 11, 2010
    Oange gave up on the Livebox & sent me a Siemans Router instead. This initially was giving 3.7Mbps but has now reverted to 130Kbps! I'm using a cable connection & Windows vista Ultimate. The ping shows. Bytes=32. Time+38ms. TTL254. When using a wireless connection on another PC. the figures are similar.
    Scholar:
  • 174 Answers
Ask your service provider for bottleneck in the fiber optic cable or change the cable I assume that your s a leakage or blockage issue with the line to the router.
Posted on Jul 04, 2008
  • Matson Kurian
    Matson Kurian Jul 07, 2008
    Please ask your service provider to change your uplink cable not your internal cables
    I hope your problem is arised from the service cable from the exchange or central hub to your home or office. Most uplink cables are fiber optics and if the connection are not firmly done there will be strength lossage from leakages or short because light rays are tavelling through it - symptom you will get everything but in a low manner according to the distance it will get more weaker.
    The ILEC or the exchange port is opened for your uplink and downlink at 5.1mbps but at your end its coming so weak. Ask your service provider to change the channel or lline to a new one also they can trace out the short or leak with cable testing devices
    Thanks Hothawk
  • Matson Kurian
    Matson Kurian Jul 08, 2008
    Thanks for your follow up can you please tell me about your network/ethernet structure, Are you using usb cable for connecting to the router
    please clarify me that what type of computers and there configuration also kindly let me know how many users are using your connection.
    Important thing you have to do - start->run type cmd enter then on the prompt type ping space your router ip address and enter post the reply result info bytes , time and TTL values
    Are you using wireless or wired connection If you are using wireless any powerful resource such as cordless phone or signal jammers around your wireless range even microwave can distrub or decrease the wireless signals
    Thanks and waiting for your comments,
    Hothawk
Broadband going slow after 30mins
sounds like your livebox is the cause of your problem , have a word with orange or whoever supplied it .
Sep 25, 2012 | Computers & Internet
Tip
Check your broadband speed and report it as a Slow/Not Spot
I have a maximum download (connection) speed of 3.5MB at my exchange which is a Local Loop Unbundling or LLU from which I live about 5km as the crow files.
My expected maximum will be only 70% of this at about 2.5MB due to signal to noise ratio loss on the BT line, dont bother trying to change your MTU or any TCP tweak settings you will probably cause more problems with the speed becoming lower maybe even cutting yourself off your own broadband connection
However most ISP use Local Loop Unbundling is the process by which third party networkoperators are able to install equipment in to BT telephone exchanges in order to provide their own services without having to touch BT's network. Only the copper pair from the exchange to the premises, which remains the property of BT, is used by the third party. Use SamKnowsBest to check what options you have at your local BT exchange
BT copper line MAX is only 8MB irrespective of the the LLU that you use this means your ISP hardware.
Optical Cables MAX is 20MB and only Virgin Media in the UK can use this transmission medium.
I used to get only 750kbps which is not even 1MB now I can get double that between about 1500kbps - 1800kbps which is still only 1.8MB depending upon the time of day.
Also make sure that your connection is not shared with another user they will steal your bandwidth ensure that if you are using wireless use a WEP or even better a WPA-PSK encryption. Close all instances of P2P or FTP uploading during the speed test.
http://www.speed.io/index_en.html
My Results as a comparision
http://speed.io/backend/result/24801225?pID=project1 750 Kbps
http://speed.io/backend/result/27957779?pID=project1 1500 Kbps
http://speed.io/backend/result/27959284?pID=project1 1800 Kbps
There is not a lot you can do other than report this slow speed to this website the more they can build up a picture of the bad or NOT SPOT areas then your ISP will have to act to ensure that you don't move your service to another provider.
http://www.broadband-notspot.org.uk/
NOTE:
If you have the same problem as me then unless you can get Virgin Media Cable that can supply upto 20MB download speeds then BT maximum 8MB speed will be your limit expect to get about 4MB using the BT copper wired pair and your ISP's own router if you live over 5 miles from the exchange.
on Jan 05, 2010 | Computers & Internet
Low broadband download speed - 0.24 Mbps
You can your isp and inform this problem....You can follow the tips below to increase internet speed.
Install Anti Virus Software or Firewall or Internet security in all devices.Software will not increase the speed of the internet.I have personally experienced in use that.So you can use the latest Browser,You can also use the Torrent to upload and Downloading ...Reset the Devices and Connection,Modem ,Router and Restart the Computer everyday.It helps to Speed up the internet.Check the speed of the internet at here Scanmyspeed.com
Oct 18, 2011 | Computers & Internet
How to check broadband speed
Before starting to check broadband speed test it is best to make sure that there are no other internet activities using your connection that might be using data, like app updates, streaming video, or online games.
Search on google there is many tools to check speed test.
Click on the start test button when you're ready, and wait a couple of minutes while the test runs. You will get an upload and download number in Mbps.
If your broadband speed is not good. I suggest you one of the best websites. Mungi is one of the best websites for broadband. They give us better speed, good connection, free services, and cheap charges. For getting more details about best nbn plans click on the link.
Jul 29, 2011 | Proxim SkyLine Wireless Broadband Gateway...
How do I test my broadband speed using a Belkin ADSL Modem Wireless Router G
Hi. Go to www.speedtest.net and select a location from the map. It will test your broadband upload and download speed.
Jun 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Bt say my broadband speed is 2.6 MPS. Internet speed tests repeatedly say its about 365KPS. BT say the problem could be my D-Link DSL Router G604T. Is this likely, please? The router is about 3 years...
Assuming your connecting wirelessly, test it by directly connecting to it with an ethernet cable and then run a speed test. If it dramatically improves, you have a wireless problem ( router, wifi card, poor reception, etc.) If it stays about the same, probably poor speed from your broadband provider.
Oct 05, 2009 | Computers & Internet
Wireless connection is slower than wired!
Yes there is a difference although most router manufacturers claim that you can get 4 or even 6x times faster than 54Mbps of a regular 802.11g wireless standard, wired connection(10/100/1000Mbps) are still faster because they are less subjected to interference unlike wireless that are vulnerable to interference like cordless phones, microwave devices, lighting fixtures, distance and the obstruction between your wireless router and the computer.
Nov 06, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Cisco aironet 350 - media disconnected
does your laptop have a switch on the side or Fn key (blue icons on the F keys) to turn on/off the wifi.
Sometimes Fn + F2 will toggle the wifi on/off.
Post your make/nodel laptop and OS for more specific advice
I avoid using client utilities with wifi. In the conection "allow windows to manage connection" and see if you can connect
Jul 10, 2008 | Computers & Internet
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
Internetrouter speed not equal
Although the router shouldn't allocate bandwidth like that, remember also that your broadband has limited bandwidth as well. What I mean is your DSL or cable modem only has a limited about of bandwidth coming in from the "outside world" to your router, which then distributes it internally. That said, that doesn't sound like much of a load, depending on what type of broadband you have. Have you checked for: a) FW updates for your router? b) driver updates for your network cards? Additionally, are you sayding from the statement "I used wires on this wireless router" that both systems were using hard-wired connections rather than wi-fi?
Apr 15, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
