Question about ViewSonic N3250W Television
ViewSonic N3250W will not turn on
The TV just quit working. tried the remote, the ON button on the TV... unplugged the TV let set for several minutes... and tried agian. Still nothing. The little green light never comes on and the TV will not power up. Even tried plugging the TV into another out let that I am sure is working. Still nothing.
I used to work on TV's a long time ago but have forgotten much. Are these new TV's easy to repair? are they costly?
Thanks
Jim
  • 4,234 Answers
Do you get a red standby light at all? If not, I'd look first for the standby transformer as being defective. There may also be a fuse right by the AC power cord. Look around inside and update this with your results. Post whether or not there is a standby. We'll need to go step by step on this one.
Dan
Posted on Jul 03, 2008
The volume won't stay at the level selected. It counts itself down to 00. I hold the volume button to raise the sound but it struggles to go back to 00. The highest setting goes to 03. I have no...
Remove the TV from the power for a few minutes, and then power on, then check the volume, effectively you have reset the set. If it still will not work, check the manual for any sleep settings etc, and work through the setup again for the channels. Now if none of that works, and it isn't a remote control issue? Then unfortunately you indeed have a problem with the set and it will need to be serviced. it will most likely be a microprocessor and ambient background noise sensor or the like, this will have to be replaced. To this end get a "Quote" from a certified repairer, and go from there?
User and service and repair manual at links below....should you wish to DIY?
http://www.retrevo.com/support/Viewsonic-N3250w-TVs-manual/id/276ag810/t/2/
http://michaeljaylissner.com/archive/viewsonic/n3250w-1_sm_1a.pdf
Oct 07, 2011 | ViewSonic N3250W Television
The Menu Screen blinks on and off while te TV is on.
Sounds like either three things are happening - 1 check your buttons on the tv and remote to make sure the menu button isnt stuck or doesnt have pressure on it to cause this 2 - your av card is bad or 3 your tv is possessed. :-) I'd check 1 and 2 first.
thanks,
michael
Apr 16, 2011 | ViewSonic N3250W Television
I have a viewsonic n3250w that won't turn on. where do I start?
Unplug the TV from the wall outlet. Press and hold the power button for about 10 seconds. Wait five minutes and then re-apply power.
Nov 26, 2010 | ViewSonic N3250W Television
Viewsonic N3250w. Power supply went out and I replaced the bad capacitors. TV worked for a week then now when I turn it on, the screen just turns on and off
Check to see if the 24vdc disappear when the screen black out, it is always there then you have problem in the backlight inverter board. Did you replace the caps in the 24vdc supply also? I replace the whole set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for yo
Sep 05, 2010 | ViewSonic N3250W Television
Viewsonic N3250W- turns on, the screen flickers on then its black
This could be a problem with the tv's memory. Try resetting the TV. Unplug the unit for a few seconds (10-60). Then restore the TV to the factory default settings. Viewsonic has changed it's menus at intervals so you may have to check your manual. It may be Menu > Setup > Memory Recall or Menu > Options > Restore Default (or something slightly different). From there, click enter, use the right or left arrow to select YES, hit enter. Leave the menu system (Menu twice). Then hit Menu > Channels and rescan all channels.
An alternative cause of the problem may be a weak signal - check that your antenna is pointing right at the station and is the correct type to get the signal at the distance you are from the station. (Usually a weak signal would also have the audio breaking up but weird things can happen.)
I hope this helps.
(who recently had a channel pair that started out with flickering signal issues and then had one channel lose video and the other audio. The memory reset and rescan resolved the problem.)
Apr 24, 2010 | ViewSonic N3250W Television
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance jah2mil@hotmail.com
Aug 22, 2009 | ViewSonic N3250W Television
ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
Jan 28, 2008 | ViewSonic N3250W Television
Televison & Video Logo
199 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
