Question about Microwave Ovens
Red Emerson Microwave, MW8992RD
I don't know what button was pressed or buttons, but when i now try to press anything, it does not turn on as usual, but numbers show upmas a countdown. I don't have a manual. do you know what i need to do to program it? thanks, denise i've tried finding a manual online without success.
  • 3 more comments
  • spiritsoul77 Jul 07, 2008
    How do I set the clock......? D thanks
  • gamblinnormi Dec 16, 2008
    don't have a manual
  • Anonymous Mar 27, 2009
    I have the same problem, we tried unplugging it, and setting the time. When we hit the time and start it does nothing, just counts down the minutes/seconds and does not function. Two lights come on the one for MICROWAVE INDICATOR, AND THE LOW COOK INDICATOR? Help?
  • Anonymous Apr 06, 2009
    Did anyone figure out the problem. We reset as instructed and it is still not heating but just counting down with the two red lights flashing.
    Did you figure out a solution for the Emerson red microwave? We tried the resetting still not working. thanks
  • Microwave Ovens Master
  • 9,086 Answers
Your manual is online here.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
After that, and following the instructions, it still has a problem, please reply back with details of how it's failing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 05, 2008
  • William Miller
    William Miller Jul 07, 2008
    To set the clock, simply follow the instructions in the owner's manual linked above.
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
I have an Emerson MW8168B 1100 watt Microwave. Start Button Problem.
the pads are touchy its probably been white knuckled too long
Apr 03, 2013 | Emerson MW8168B Microwave Oven
Emerson Microwave Model MWG 911156: I cannot determine how to set the hour on the clock. After I press the "clock" button, what do I press to get it to the correct hour?
Usually the minute and seconds or a combination of the timer buttons will work it. If it has no hour then the minutes must be used as a dual use button.
I have looked on the web and cannot find a photo of the front panel to refresh my memory.
Hope that helps.
Jan 19, 2011 | Emerson Microwave Ovens
My emerson just quick working the timer is on but it isn't doing anything. I unplugged it thinking it may have reset but it didn't. How can I fix it?
I have a similar issue with this machine. For your problem, try this...Press and hold the STOP button for three seconds. This is intended to turn off the "Child Lock Out" function. On the other hand, you may find that buttons that do not work today will be fine in a few hours and different buttons will not work. It seems that every time I press a button, it's "pot-luck" if it will work or not.
The only way to repair it is mail it to California at your own expense and include a check for $15.00 for handeling. Target won't help and if you bought the extended plan it only kicks in after the emerson waranty runs out. If you buy this machine, buy another brand as well so you have one that works while this one is out being repaired.
Oct 24, 2010 | Emerson 025806092806 Microwave Oven
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8119SBM microwave. Use popcorn button.
Try clearing the microwave before pressing the popcorn button again.
Feb 21, 2010 | Microwave Ovens
Need to replace the glass tray for Emerson Microwave Oven model #MW8992RD
Glass tray replacement for the Emerson Microwave MW8992RD has been discontinued.
Oct 06, 2009 | Emerson Microwave Ovens
Mw8115ssw no power
There's no reset button, only a a hard reset. Unplug the unit for a minute or so. Then plug it back in and see if ti works.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Jan 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My emerson MW8992RD the red metal one displays all zeros and the button will not work at all!
The keypad may be damaged or worn out, or control unit may be damaged.
I would suggest that you contact Emerson. It may still be covered under warranty.
Dec 01, 2008 | Microwave Ovens
The fuse blows when i plug the microwave in with the door closed
first you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
Nov 16, 2008 | Microwave Ovens
Microwave Ovens Logo
1,756 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
