Question about Gateway 7330GZ Notebook
Dual Monitor Support for Gateway Laptop
I purchased a Gateway laptop from Best Buy a year ago. I recently purchased an external monitor. Does the Gateway laptop software support dual monitoring? If not, is there a software download available? While I had to select a model from the list, I am at work and do not know the exact model number at this time.
  • 32 Answers
Search on google for does gateway software support dual monitoring.
Posted on Jul 03, 2008
My display is black no num lock &caps light the internet key wont light up it stays amber color. it seems like its on but display will not turn on
You will not get a picture on the other laptop from the monitor out. You need an external monitor.
Surely the old laptop is under the manufacturers warranty?
Oct 09, 2014 | Computers & Internet
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
Have recently acquired agateway laptop . sn lswsg0200403765a271601. the monitor screen is fractured but is still trying to function. am currently using computer with adetached monitor. what are my...
Get your screen from Ebay it should not be that expensive ranging from $65 to $100 then if you are good with dissasembly and assembly you can change it or look for someone who can help you do it.
Jun 09, 2011 | Gateway Computers & Internet
I have a NEC laVie LC800j/8 laptop and i have installed windows Xp SP3 recently. but it have not any sound.it is necessary to say that the laptop is safe quitely and prior OS have been Windows XP SP1. what...
I have a Lavie e Lc500/3 model laptop.But few days ago monitor don't display anything but i connect another monitor with laptop external vga port that time monitor work properly.
Apr 07, 2011 | NEC LaVie S LS900/8E Notebook
I bought hp dv2630ea laptop 3 years ago, recently my laptop screen went into blank, no light, no image on the screen. i brought it to the hp service authorized center in hyderabad, they said problem with...
The LCD screen may be faulty. I suggest you borrow a monitor to test your laptop if you do not already own one.
If the laptop appears to boot up and the hard disk LED flashes, then connect an external monitor to the laptops video port. Power up the monitor and then boot up the laptop and the video information will automatically divert to the external monitor.
If this works then you have a working laptop.
Dec 09, 2010 | HP Computers & Internet
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
I recently purchased a ASUS K60 Notebook from best buy. I am using Windows 7. I am trying to hook it up to my 42" inch LCD tv via a VGA cable. My problem is that when I do all I am getting is my Desktop...
Since you are using a laptop to connect to an extended monitor, follow these steps:
  1. Make sure that both the laptop and TV are on.
  2. Connect the VGA cable from the laptop to the TV.
  3. Then hold down the FN key and the function key with the TV/Monitor icon like the one below to switch to dual monitor display mode.
Jun 09, 2010 | ASUS K60IRBBBR05 Notebook
Where can I buy a lcd cable for a md2614u?
If you mean for connecting an external LCD display, the cables are available in store or online:
Fry's
Best Buy
maybe Office Depot/Max
Your laptop has a VGA monitor port, not a DV/I port, in case you are asked...
Oct 08, 2009 | Gateway Computers & Internet
Hooking 2 monitors to laptop?
Only way is to replace your lcd screen if you dont want to spend on a external video card,heres a parts break down of your machine ,
http://supportapj.dell.com/support/edocs/systems/ins8500/en/8500/sm/system.htm#999507
Cheers Misterdj
Honestly buy the external card or a second 8600 and transplant the lcd
Please rate me thanks
Aug 12, 2009 | Dell Inspiron 8600 / Latitude D800 /...
CPU On Monitor Dead
The monitor, since it is under warranty is best to be examined by an authorized personnel or replaced. As for your laptop, I dont suppose it has a problem. Only that it should have been configured to send display to the external source once plugged.
There are 3 options
  • Native + External
  • Native alone
  • External alone
Your laptop is configured for the 3rd option. You can change this by getting into display properties and under your graphics card configuration. Please do comment if you need further assistance
Jul 25, 2009 | Westinghouse L2046NV Monitor
Gateway 7330GZ Notebook Logo
279 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
