Question about Sony FD Trinitron WEGA KV-30XBR910 30" TV
TV Blinks 7 times
Can anyone tell me why my Sony Trinitron, model kv30xbr910 is blinking 7 times, no power? I understand that it's a power issue, anyone know how it can be fixed? what part do I need etc? This tv is only 31/2 years old
  • kelicloyd Jul 08, 2008
    any chance you've found this part? can i get a service manual through you?
  • boater2786 Sep 20, 2008
    I have the same problem with our Sony KV30XBR910 tv. Can you give me the part number for the "D" board and where I can get this part?
    Thanks.
    Ryan
Same problem here. I was told the part is no longer available or being made by sony.
Posted on Oct 21, 2008
  • 4,234 Answers
The 7 blinks indicate a safety shutdown due to over-voltage in the high voltage section. The high voltage has exceeded 33,000V. This is usually a problem with the power supply regulator. I need to look up the specific part for you. If you are comfortable working inside the set and can solder, you should be able to repair this yourself.
Dan
Posted on Jul 03, 2008
Sony FD Trinitron WEGA KV-32HS500 --had the 7 blinks problem, took out D board and resoldered pins--didn't work. But now it blinks 3 times!!\r\n . . .I guess I still have to replace those IC's Anyone have...
On some models 3 blinks pertain to a lamp cover error, lamp cover is not attached securely or lamp is not set securely causing no picture or sound. There are switches or sensors that interlock and send signals to the board telling it is set securely.
Feb 28, 2011 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Still Need Some Help
SOny has had big problem with BAD picture tubes so when tube begins to short in return it will burn flyback transfomer ,shorting out hori output.I know i thru away better then 50 sonys all with same problem. some of them where only a year old!
Jul 18, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony Blinks?
help, dennistredden@comcast.net
sony 32 trinitron tv
takes awhile to come on then when it does it blinks all the time..
sometimes it stays on for a few minutes but then goes back into a blink mode..
can you tell me what is wrong and where, online can i order the parts. I've never worked on tv's but i don't have the money to call some one.
thanks in advance
mr. redden of highland, mi.
May 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV 32FS120
Hiii...
I'm not certainly sure how many time the led blinking ?
I hope hear from tou soon...
Thank's
[Vrya]
be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
36 inch sony wega trinitron
I had the same issue earlier this week. 4 year old sony trinitron wega 32 in. I was told by Sony to call technician to repair and have called tech....could be anywhere from $200-$300 repair. I did research the blinks (google "sony blinking codes" to find out what each means) Ours was 6-7 blinks which meant power surge to tv. I advised to Sony that i saw many of the same issues with many of the newer tv's and suggested a recall issue--they denied and where no help.
I will buy a new tv now--definitly not a Sony.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony TV
Blinking what - how many times before it pauses and then blinks the next set?? Sonys have an error code of blinking to help isolate the problem... (count the number of times it blinks before pausing and let me know).
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Logo
196 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
