Question about Lexmark JetPrinter Z55 InkJet
Lexmark Z55 When I try to print , the computer recognizes it and says its printing but the printer doesn´t print. Downloaded a patch from Lexmark but after installing it is says USER CANCELLED and won´t print. Any ideas? Thanks!
  • shaca Sep 15, 2008
    Thanks for answering! Yes-it said the printer was not connected, but obviously it was.
    Problem Solver:
  • 7 Answers
Does an error message appear on the computer screen?
Posted on Sep 14, 2008
  • Aileen Estoquia Sep 16, 2008
    there could be a number of reasons. have you tried the following?
    1) disconnecting and reconnecting the USB cable
    2) using another USB cable - perhaps a shorter and newer one
    3) plugging the cable into another USB port on the computer
    4) removing the power supply from the back of the printer and then plugging it in again (make sure the printer is disconnected and turned off when you do this)
    5. enabling the USB port on the cmomputer
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
I have a laptop that has vista OS and when I try to print using my Lexmark p3150 printer I get a "trouble communicating with the printer" warning. Is there a driver that will correct this? I...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ieDcBl. Select your operating system, download and execute the file.
Sep 21, 2011 | Lexmark P3150 All-In-One InkJet Printer
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
It want print anything!
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
Sep 12, 2011 | Lexmark C533DN InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Wont print
4. Reboot your pc.
Aug 21, 2011 | Lexmark X4550 AllInOne InkJet Printer
MY LEXMARK 1270 CANT PRINT NOR SCAN BUT ITS STATUS IS READY
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X1270 All-In-One InkJet Printer
Every time I try to print a screen comes up that says communication problem, I have checked everything and I cannot get it to print please
  4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW.
Aug 11, 2011 | Lexmark X2600 InkJet Printer
Z55 printer working with Dell Inspiron 530s
I have LexmarkZ55 printer which I have been using for years then all of sudden it stated that printer is not communicating with the computer and somthing wrong with the cable. I bought new one it still not printing.
Feb 13, 2008 | Lexmark JetPrinter Z55 InkJet
Lexmark JetPrinter Z55 InkJet Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
