Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
  • anglia64 Apr 04, 2009
    Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451. Every thing was working fine and then boyh batteries would not charge, 2 flashing lights on charger. Help is it the charger or batteries. the drill is little used and 15 months old.Help to neilweatherald@hotmail.com please
  • olsenfix May 22, 2009
    I have the same proble with one of my two barreties. Have only charged it a few times.
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Posted on May 27, 2009
When its charging it flashes green & red and won't take a charge
If it is a Makita battery charger it means the battery has died or has an internal fault, or is too hot.
Take it out of the charger, let the battery cool down if required and try again.
If both red and green lights are flashing, try a different battery.
It might be time for a replacement battery.
Mar 21, 2015 | Drills
Red light flashing will not charge battery have left over night with no result
Sometimes, this is a result of a battery that is too cold (below freezing-warm it up). Sometimes it can be too hot (discharged under heavy stress-let it cool down). Sometimes there may be insufficient voltage, I have had problems in older houses, get closer to the electrical panel to plug in, or you may have to wait until you get home. Red flashing may mean https://www.youtube.com/watch?v=8rZqYmPsZycthe charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been dropped or hit the floor the coil inside could have broke loose and damaged the charger requiring it to be replaced. Below is an unconventional way to charge the battery if the charger is no good. BE CAREFUL
how to charge broken makita BL1830 Li ion battery
Mar 12, 2015 | Makita Cc300dz 10.8V Li-Ion Cordless Tile...
On the e -flite 2-3 cell lipo balancing charger,
That's what's happening to me I bought another battery it still didn't work so I thought it was the charger I bought a new charger and the same thing happened now I don't know what to do
Oct 26, 2013 | E-Flite Eflc3110 2-3 Cell Lipo Balancing...
After charging battery, when I press start, it attempts to start and then immediately shuts down. After recharging the battery a while, and attempting restart, the same thing happens again.
Hi
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
Jan 10, 2011 | Averatec 3200 Notebook
Anomalous charging behaviour :- a) plug in discharged battery b) starts off with the yellow light flashing as usual c) after a very short time the lamp goes off completely - instead of staying on...
Okay, might not be reading this right but here goes. If the camera shows the batteries as full then I'd go with that. The charger will come on for a few seconds even with a freshly charged battery because it take that long for the charger to realize the battery is already full. You can't feed an already full battery, so the charger is shutting off completely. Yes normally the light would stay on and the charger would continue to trickle a charge into it it until it is removed. In your case I think you have those batteries stuffed to the gills so the charger is shutting right down. One of the problems with these batteries is as much as the manufacturers deny it they form a memory. Best thing to do with these rechargeable batteries is drain them right down and then replace with a freshly recharged battery.
Dec 17, 2010 | Nikon MH18a Battery Charger
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
I went snorkeling with my olympus 780sw camera last weekend and was taking photos just fine. It was nearing the end of the battery life I believe and when i went to try to turn it on, nothing happened so I...
I have the same problem with my 770 SW. The funny thing is, some outlets in my house will allow it to charge, some will just make the light flash. I found your question looking for a better solution. Try all the outlets in your house with the charger, I know it sounds silly, but it works for me.
Mar 05, 2010 | Olympus Stylus 790SW Digital Camera
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Ryobi battery charger
Either the battery is hot from use or has been in the sun, let it cool down, then try again.
Nov 16, 2008 | Ryobi Multi-Volt Battery Charger
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
1,214 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
