Question about HP Compaq Business Notebook NX9005 Notebook
HP NX9005 Keeps restarting/rebooting
When you power on the device, it continues to restart until you remove the power source.
There is no change if you remove the hdd, ram or battery.
Further details can be found here...
http://www.daniweb.com/forums/thread56509.html
    Genius:
  • 2,028 Answers
This is know as cyclic redundancy, and the cure is (I really thought about cutting it short right here after reading that thread, but I'm not that mean) I've fixed this in two manners 1- a bios flash if the machine will take one. Most of the time you won't get that far, and when you do sometimes it doesn't last long before the same problem arises. Then we come to #2- replace the motherboard. I know that nobody wants to hear this, but it seems to be the only real cure. HP has the shittiest most fragile motherboards on the market, on some that I've replaced, when held to a bright light, you can see hairline fractures in them.
ie.. when a friends fell from the couch cousion to a carpeted floor the same problem occurred and you can see the crack, it's very slight but it's there.
Posted on Jul 03, 2008
My iphone 6 keeps rebooting, I've already done a hard reset several times and a safari clear history, no good
hi Vardi.
i know you have said you have done a reset but this is all i could find out.
To perform a hard reset, hold the power button and Home button (the circular button below the screen) at the same time until your iPhone screen goes blank and the Apple logo reappears. ... People were amazed when they'd come into the Apple Store and I'd quickly fix their deadiPhone with a hard reset.22 Sep 2017
Why Does My iPhone Keep Restarting? Here's The Fix!
https://www.payetteforward.com/why-does-my-iphone-keep-restarting-heres-the-fix/
Why does my iPhone keep restarting itself?If iPhone iPad Keeps Restarting Randomly. You can restart or force-restart youriPhone iPad to clean all processes, which may help you fix "keeps restarting" issue. To force restart one device, just press and hold both of the "Sleep" and "Home" buttons at the same time for 10 seconds until Apple logo appears on screen.
What do you do when an Iphone keeps turning on and off?To do so go to settings ? Cellular/Mobile ? Turn On/Off Mobile Data. RebootiPhone: To reboot your iPhone, hold the power button and home button simultaneously for a few seconds. The Apple logo will appear on the screen and your iPhone is rebooted.24 Mar 2014SOLVED: My iPhone keeps rebooting/shutting down by itself? - iFixithttps://www.ifixit.com/Answers/.../My+iPhone+keeps+rebooting-shutting+down+by+itse...Search for: What do you do when an Iphone keeps turning on and off?
or go to this link.
iphone 6 keeps rebooting Google Search
Dec 02, 2017 | Hard Computers & Internet
I'm using a Hp compaq nx9005. It has being working
did you try to restart from "last known good configuration"? if it doesn't solve your problem do this: on Windows Advanced Option Menu, pls select an option "Disable Automatic Restart On Your System Failure" then post here the error message.
Mar 03, 2013 | Computers & Internet
Hp dv9208nr with vist sp2, system keeps rebooting, screen stays blank, cant even get to bios
hi,
When the files in your system are corrupted, your HP laptop would reboot automatically. When the files which are required to run the Operating System like fonts under Windows FONTS directory are been smashed then your system's Operating System will force your HP Laptops to restart continuously. Thus in such a situation you would have to change the name FONTS in the Windows directory.
Get more help to fix HP Laptop Keeps Rebooting error . Hope this helps you.
Apr 24, 2011 | HP Pavilion dv9000z Notebook
My hp 519j XP freezes when I reboot or if it sits on for awhile -- screen shows on the bottom: <Esc+Boot Menu> <F1=Setup> <F10=System Recovery> but those 3...
press del and get into bios click optimizes settings then save and exit if still the screen doesn't go further remove the power from the hdd and the ide cable or sata cable and remove all the add on cards and restart the system when you restart you find no boot device connect the ide to the primary ide connector and restart your computer if the page doesn't show no boot device change your ide cable
Dec 15, 2010 | HP Pavilion Desktop, 3.06GHz Intel Pentium...
Does not start
step 1 check the chord or the charger for your notebook its broken or good to use..
ste2. remove the battery from the notebook and press and hold the power button on the notebook for 4-5 sec and then put the battery back and then try to restart the notebook
Aug 19, 2010 | HP Compaq Business Notebook NX9005...
How to restart iphone with broken power button
There is no other way to switch on or off the iphone apart from the power button.
Jan 02, 2010 | Apple iPhone 3G
No recovery discs
If you have any windows xp bootable cd use that to fix the problem by running the command chkdsk /r/f or you can try with this just restart the system in safe mode with command prompt and type the command like c:\windows>chkdsk
And
c:\windows>chkdsk /r/f
Sep 15, 2009 | HP Compaq Business Notebook NX9005...
Ethernet card driver for winxp Hp Pavilion dv6000
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Jul 17, 2008 | HP Pavilion dv6000z Notebook
Hp labtop nx9005 need to restart
Witch password?
Admin password?
Power ON password?
Email me : fixya-expert@live.com
Feb 12, 2008 | HP Compaq Business Notebook NX9010
HP Compaq Business Notebook NX9005 Notebook Logo
190 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
