Question about Fisher Washing Machines
My washer i need some one to come to my house and fix my washer
    Novelist:
  • 177 Answers
I would start with where you bought your washer.
If they are not available, look in the yellow pages for someone who works on your Washer Manufacturer. There are alot of competent technicians available. you could also ask neighbors friend or coworkers who they would recommend. I would try to find someone who has been in the area and is established. If they cant fix it they will make a recommendation on a replacement.
Your service tech make give you some advise.
Sometimes its hard to justify buying new. however I would not stick more the half of the replacement cost in a repair.
Best of luck! T
Posted on Jul 03, 2008
Last night, the breaker tripped and we have lost power to the stove, hot water heater and the washer. We reset the breaker however, it dosnt seem like it is pushing enough power out for the stove, hot...
That means you have only one live wire running the whole house. If this happens the power sneaks through a 220 volt appliance and feeds the other half of the house but at reduced power (a brown out) This may damage appliances. Reset the main to the house. If it still isn't fixed call the electric company in your region to fix the wires feeding your house
Nov 26, 2013 | General Electric Electrical Supplies
Water leak where the gun hose connects to the washer causing very low pressure 2200 psi model 020245
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Jun 08, 2011 | Garden
My estate washer continually runs water in the basin but won't fill up. It drains immediately out as the water runs in. What could be the problem?
Assuming the motor isn't running during fill the water is siphoning out and can be caused by a few things.
· The drainpipe to your house may be too low and you either need to extend the pipe up above the top of the tub or run the drain hose from your washer up high.
· Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break.
· If the drain hose from your washer is pushed down the drainpipe too far, this will also cause the same problem. To fix it just pull it out to within about 6 inches of the end of the drainpipe.
Feb 08, 2011 | Whirlpool Washing Machines
HI my name is ismael and i have a problem with my 27 inches stacked washer when we turn on the washer in all cicles the tank do not keep the water in automaticle the water start drain out thanks for your...
Oct 30, 2010 | Whirlpool LTE6234D Top Load Stacked...
I left my electric karcher pressure washer it in the shed during the winter and they tell me that the housing and the safety valve need replacing. Can I repair it myself? They want 180.00 to fix it which...
Is there a leak from the bottom ?
If so then there is a crack in the Manifold housing. A New Manifold Complete Replacement is approx. $61.03, can be purchased from Karcher.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
Apr 29, 2010 | Karcher PSI Electric Pressure Washer
Moved into rent house and washer drain backs up and overflows
If the washer isn't yours (ie., it was included with the house and not one you bought), don't bother doing anything yourself - tell your landlord to come fix his/her washer!
Oct 26, 2009 | Maytag Washing Machines
When starting the wash or rinse cycle, the washer keeps filling and the water is draining out like it would do before the spin cycle...
Assuming the motor isn’t running during fill the water is siphoning out and can be caused by a few things.
  • The drainpipe to your house may be too low and you either need to extend the pipe up above the top of the tub or run the drain hose from your washer up high.
  • Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break.
  • If the drain hose from your washer is pushed down the drainpipe too far, this will also cause the same problem. To fix it just pull it out to within about 6 inches of the end of the drainpipe.
Oct 11, 2009 | Frigidaire GLWS1339CS Top Load Washer
Tub won't fill with water so that we can add dye for dying clothins; Water runs and drains, won't fill tub
  • Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break,
Sep 07, 2009 | Washing Machines
High (incoming) water pressure in house
You only have to regulate the incoming valve in your wall (to the washer) to have safe pressure.........don't see any reason why you can't do this.........& get on with your tons.......
Nov 27, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
