To clear the clog, remove the hose and wand from the unit and separate them. The hose is released by pressing the white plastic ring in the housing. The two are separated by simply unscrewing them. Remember this threaded connection uses a left-handed, or reverse, thread. By looking through each of these pieces, the user can ensure they are not clogged. To check the lower hose, it is easiest to lay the unit on its side. Remove the glide sole by turning the yellow turn locks to line up with the slots and then removing the glide sole. Remove the yellow connector the wand was plugged into. You should be able to see the brush through the hose from the rear of the machine.
We checked the hose and made sure it was clear as you suggested before we sent you this question. Is there anyplace not obvious that could be clogged? Unfortunatly we don't have a manual for this machine and are not familiar with the inward workings. Any other suggestions?
