Question about Whirlpool Dryers
Remove the drum from a Whirlpool gas dryer. Model LAI 5521
    Novelist:
  • 177 Answers
First always unplug the dryer. Safety first!
Next once you remove any panel you have to watch for sharp edges we call it whirlpool rash!
remove the bottom panel it could be held in with clips on the top. use a putty knife to release them. Then on the top of the dryer remove the lint filter and take out the screws. At the front of the dryer where the front panel meets the top using a putty knife to push the clips the top will come off.
Now you will need a socket or wrench to remove the front panel. before you do that the wires to the door switch will need to be removed from the front panel. mark them in some way so you know which one goes where. Remove the front panel and then the cylinder will be accessible. However before you remove the cylinder "drum" look at the belt and how it goes on the motor. you need to remember how the belt goes back on! very very important. Now remove the drum and it time to vacuum out all of the lint, and do some PM, a couple drips of a lite oil, like sewing machine oil on the shafts of the wheels at the rear of the drum and the idler wheel. Reassemble in reverse.
When you put the belt on the drum, ribs down, and the extra belt hangs on the bottom, making sure the belt is in the correct spot, with no twists. Now the fun begins put the belt thru the idler and on to the motor pulley. once this is done turn the drum several times to make sure the belt doesnt come off. continue with reassembly and ask if you have more questions.
T
Posted on Jul 03, 2008
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Mar 31, 2011 | Whirlpool Dryers
The dryer sounds like a fifty pound weight is tumbling in it, and I see a split in the drum at the rear outside periphery and its not even tree years old yet.
you will need to take the dryer apart, and inspect the drum and if it is split then you will need to purchase a new drum or dryer:
http://shop.ebay.com/i.html?_nkw=whirlpool+dryer+drum&_frs=1&_sop=16&_trksid=p3286.c0.m359
how to open dryer:
http://www.partselect.com/dryer+remove-drum+repair.htm
you will also want to inspect the drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 25, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
Drum turns but does not heat the air. I replaced the ignitor, but no help there. Whirlpool gas dryer model 63003W0
If the ignitor glows but does not light the burner you need to replace the gas valve coils.
If there is no glow you must check all the thermostat safeties and thermal cutout fuses for continuity with a ohm meter. No continuity is a bad component. Remove at least one wire from each component before testing.
Unplug the dryer before any test.
Feb 17, 2010 | Whirlpool Dryers
Whirlpool gas dryer, drum doesn't spin
You have a broken or loose drive belt.
You can order a new one online (repairclinic.com) have your make and model numbers handy.
There's also exploded views to help you.
You'll need to remove the front panel and drum front panel, the drum and route the new belt around the tensioner pulley below the drum...
It's a bit tricky but if you take your time you'll be able to do it..
Let us know if you need assistance with disassembly.
K
Oct 17, 2009 | Whirlpool Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
Dec 21, 2008 | Whirlpool LER4634J Electric Dryer
Parts diagram
Request the diagrams you need directly from Whirlpool
Oct 09, 2017 | Whirlpool GGW9250PL Gas Dryer
Dryers Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
