Question about GE Nautilus 24" Built-in Dishwasher
Cycle stops, won't drain
The dishwasher starts but midway through the cleaning cycle it seems to get stuck. Won't move forward through the cycle, just keeps running / cleaning. You can click it over manually but on it's own it gets stuck between cleaning and pumping out the water.
model #GSD3425400BB
  • brittb1 Jul 04, 2008
    Mine seems to finish its cycle, but will not drain either.
  • Anonymous Nov 17, 2008
    i have the same pblm w/my ge nautilus. turns on and runs, but wont move thru the cycle (drain/rinse/heat dry)
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Posted on Jul 05, 2008
Belling dishwasher won't empty. I have cleaned the water filter and the machine worked fine this evening it won't empty?
Search Results
    Belling won t drain Dishwashers Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > won t drain > Dishwashers
    Belling dishwashers won t drain related questions and answers. Ask your Belling questions. Get free help from dishwasher experts.
    How to fix a dishwasher that won't drain - Dishwashers ...
    www.which.co.uk/.../dishwashers/.../how-to-fix-a-dishwasher-tha...
    Which?A dishwasher that doesn't drain can cause concern in your kitchen, but you may not ... Check out our video to see how to repair a dishwasher that won't drain.
    i have belling dishwaher which is not emptying e1 showing as
    www.justanswer.co.uk > Appliance
    OK, so it fills and starts the cycle and then won't drain and this error will flash ... is ... the washing machine which is at the side of the dishwasher has been giving ...
    How to Fix a Dishwasher That Will Not Drain - YouTube
    ? 2:13
    https://www.youtube.com/watch?v=nr6tIO5iNSc
Feb 08, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
The clean button blinks. the only button that works is the drain button.
Hello
Confirm that the door is closed and latched. dishwashers can detect if the door is open and will cancel any cleaning cycles to prevent water spillage. Wait for around 20 minutes before unplugging or moving the dishwasher in case the washer is cooling down, draining or drying dishes. Call a technician if the dryer does not restart.
Verify that a cycle has been selected using the "Cycles" button and that the "Start/Resume" button has been pressed. Unlike some models of dishwasher, appliances won't start until you select a cleaning cycle and press the "Start/Resume" button.
Confirm that the dishwasher's electrical outlet is switched on, if necessary, and that power is being supplied by plugging in a lamp. You may need to replace a fuse or reset a breaker on the electrical circuit if the lamp will not work in the outlet. Ensure that the dishwasher is plugged into the outlet.
Ensure that the water shutoff valves at the wall are open and that the supply hoses are free of kinks. Your washer will not start if it is unable to access the water supply. Most shutoff valves need to be turned clockwise or moved to the "Open" position to work properly.
Open the door and check the overfill float in the bottom of the dishwasher. Push it down to make sure it can move up and down freely. The machine will not start if the sensor is stuck at the top. The overfill float looks like a small cone on top of a disc with a paddle attached to the side.
Sep 12, 2011 | Whirlpool DU1055XTV 24 in Builtin...
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Kenmore dishwasher stops midway through
http://fixitnow.com/wp/2006/03/29/whirlpool-kitchenaid-kenmore-dishwasher-poor-cleaning/
Here is a good page that can help you resolve this issue and buy the parts needed
Feb 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
366 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
