Question about HP Photosmart C5180 All-In-One InkJet Printer
Hp c5180 won't print black
I've replaced the black ink cartridge and tried cleaning the connections as well. I've done head cleanings and alignments. Still no luck. HP TechSupport will not help since printer is out of warranty. Is there anything I can do or is this hardware trash?
    Scholar:
  • 133 Answers
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. This technique reprograms the electronics to a certain extent.
You can also visit the HP website, which provides solutions to various printer problems. Anyone can access this information. Some solutions are specific to your model and some are applicable to other models. You might have to sift through a few pages of solutions, to get to the ones you want.
Hope these suggestions help you out.
Posted on Jul 04, 2008
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
How do I clean the print heads? My black ink will
  1. Load unused, plain white letter or A4 sized paper into the tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center
HP Solution Center opens.
  1. Click Settings.
  2. Under Print Settings , click Printer Toolbox . The Printer Toolbox opens in a new window.
  3. Click the Device Services tab.
  4. Click Clean the Printhead .
  5. Follow the prompts on the screen, and then click Done .
May 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Will not print black with new ink cartridge
If you used an after market ink cartridge or the print head may just be dirty. try using ammonia to clean the print head.
May 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
My 5180 will not print black. it has a new cartrigde
Your print head is separated from your cartridge. I think that your print head is clogged, and that is why you can't print even with a new cartridge. The cartridge in your case is just a tank with ink, the print head is inside the printer.
You can do a software cleaning to unclog the print head.
  1. Click "Start", then "All Programs", then click on HP and then click on "HP Solution Center"
  2. Click on "Settings"
  3. Click on "Print Settings"
  4. Click "Printer Toolbox"
On the "Device Services" tab, click Clean the Print Cartridges and then follow the onscreen instructions. There are three levels of cleaning available, depending on how long you haven't print.
When the printer is done, it should print a test page. If everything seems ok, just print. If not, you will need to repeat the procedure.
You should also know that software cleaning uses a lot of ink.
Hope that will help solve your problem!
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Bogus message to replace print cartridge
To resolve the issue remove al the print cartridges and clean the print heads. Now insert all cartridges and try to align the printer. Click here for instructions to align the printer.
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
691 people viewed this question
Ben Johnson
