Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Bissell Powersteamer It will spray out water and solution but it will not **** it back up. Any suggestions?
  • 417 Answers
theres a small red filter in the head of the machine that gets clogged with hair and the machine wont draw as good, you have to find that and keep it cleaned out. FYI also-if you have pets you have to stop every few rows and check the floating bar mechanisms keep them free of hair or they will overheat the bearings and snap belts and eventually melt the bearings into the brush bar..
good luck
Posted on Jul 09, 2008
Not spraying or picking up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Feb 02, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a bissell powersteamer model 1697 that does spray water any more. Will a new water pump solve my problem?
check all lines from being gloggged /also check screen in the water tank on hose can you here the pump working
Oct 20, 2008 | Bissell Vacuums
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Mar 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
75 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
