Question about GE DBXR463EBWW Electric Dryer
Dryer starting problem
Dryer starts without the use of the start switch, anytime timer switch is in any position except off.
  • 1 more comment
  • jameshall2 Jul 17, 2008
    I replaced the start switch and solved the problem.
    James Hall
  • crystaljones Aug 09, 2008
    the dryer makes a humming sound when you turn the start knob but the inside barrel does not move.
  • coachcraig Nov 09, 2008
    my G E dryer starts without the use of switch any where you put the timer the dryer starts, also when you open the door it stops running like normal, but when you shut the door it starts running again without off-on switch
    Genius:
  • 1,122 Answers
Weak motor ,replce-mike
Posted on Oct 15, 2008
Timer does not tick and dryer does not reverse direction
The timer not moving is a sure sign it needs replaced. Fortunately replacing it is easy. Just search for your make and model dryer and order the timer. Remove the power, the back panel with the timer, the knob on the timer, and just a couple of screws and it's out. One by one move wires from old timer to new, install the reverse as taking it out. Put the knob back on, and the back panel. Plug it in, and you should be golden.
Ah, I just saw you answered in your own question! Good job! :-)
Anytime the drum turns, with or without heat, and the timer makes noises, doesn't move, has to be wiggled to start, or the start position changed, you can bet it's the timer. We just don't want to take a risk because it's one of the most expensive parts to replace, usually the motor costs a bit more, but seldom go out. Don't waste time troubleshooting other parts if any of the above applies, it's usually the timer.
Aug 30, 2015 | Dryers
Why doesn't the timer function?
Most likely, the timer is defective.
Jun 30, 2015 | Dryers
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
Hello there and thanks for choosing fixya
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
dryer_door-switch.jpg Door Switch
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
dryer_start-switch.jpg Start Switch
A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
dryer_thermal-fuse.jpg Thermal Fuse
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
dryer_thermostat.jpg Thermostat
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
dryer_timer.jpg Timer Motor
Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly.
dryer_motor.jpg Motor
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
Jan 23, 2011 | Dryers
Dryer would not start but as i kept turning start switch it came on
timer switch is going bad go have it tested
Apr 23, 2009 | Dryers
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Doesn't stop
The problem is probably the plunger switch that you press to start the dryer. If you select the OFF position and then move the dial to a cycle, does it start running without you having to press the start button? If so, that switch is your problem.
If you disconnect the dryer and remove the rear panel, you can unplug the switch and repair it yourself (the contacts probably just need to be adjusted) or you can replace it. Depending on the dryer you might be able to get the part number from the inside cover of the rear panel.
Apr 17, 2008 | KitchenAid KEYS750LQ Electric Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
74 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
