Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Does not leave Drian Cycle!
Hello!
We have run into a very serious problem at home....our Kenmore Front Load Washer HE2 has stopped working only after 2 years of having purchased it! Sears wants us to wait 2 weeks before any service technician can come and inspecting it! With four children in the house, this is a major problem for me. Can anyone help.....(it would be much appreciated!)
The problem is that the washer does not seem to leave the drain cycle. Initially I thought that the drain pump had been damaged as I found a sock in its filter. After removing the sock, the problem did not go away. So I drove 60minutes to Sears Parts & Service store in St. Laurent, Ottawa! I purchased a new drain pump at the high cost of $102 (including taxes) and installed it on my machine. The problem did not go away! So my suspicion now is that there is some dirt on a sensor or the CPU is toast. I tried adding hot & cold water in the machine. But when I turn the washer on, the water simply gets drained. But the washer also stays permanently in the drain cycle. After a few minutes, the washer stops with diagnostic code F21. (ie: Add a Garment; Rinse; Clothes Clean). This code was the same prior to changing the drain pump.
PLease, would you have any ideas what may be wrong? Note that I have called many independant servicing businesses around my area, but no one wants to touch the Kenmore's! Maybe my machine is too new.
Thanks in advance.
Best Regards,
Sami.
Ottawa, Canada
It's most likely the pressure switch, had a similar problem and i replaced that switch and it fixed it... if you are facing the front of the machine with the top off its in the far right part of the top of the machine. There is a brown and white round plastic piece, it has one plug in the front (plugged into it) and a small black hose on the bottom. Order the part from sears.com and unplug the one plug going in, remove the bottom hose, twist the entire switch 90 degrees and remove it (careful not to break the clips). Reinstall the new one and it should be fine.
Posted on Jul 28, 2008
    Genius:
  • 1,028 Answers
Remove front panel again on back side of panel is tech sheet with code explanation sorry can't remember all the codes but i thing you may have a bad water pressure switch ..remove top back right side with small hose cost less than the pump
Posted on Jul 05, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
How do you clean the inside of your Front Loading washer?
This can be accomplished by running the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
140 people viewed this question
Sal De
fordexpert
Robert Rankin
