Question about Ricoh Aficio CL3500N Laser Printer
Replace toner bottle?
HI,  my printer is asking us to replace the "toner bottle" but I neither know where it is or how to replace it... help please!!!
  • 417 Answers
Toner waste bottle located at the front of the machine where the toner goes. Open the front cover as if to replace toner. to the bottom right s a little clear plastic tank. remove it and vacume all the toner out of it then install it again this will make it work.
Thanks Jason
Posted on Aug 17, 2008
  • Ricoh Master
  • 691 Answers
You can download the user manual from the Ricoh web site. The manual tells you how to replace the toner bottle.
Download it from HERE.
Posted on Jul 06, 2008
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
Oct 02, 2008 | Samsung CLP-500N Laser Printer
Help me to reset error codes c0070 & cof32 on minolta bizhub 210
C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also.
Jan 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
How do I replace the waste toner?
The waste toner bottle is just a bottle that the old unused toner falls into. It is located on the right side of your printer. Open the right side door, and the waste toner bottle (which is wide and flat) is in plain view taking up the bottom half of view. It has a sliding lock on top. Slide the lock to 'unlock' and remove it. Replacing it is easy - just reverse and make sure to lock.
Jul 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Used toner bottle is full how to solve this problem by our self.
I don't know what make and model copier you have but empty out the toner bottle into the trash and reinsert the bottle. If you empty it and you still the error code clean the bottle out and it should go away.
It may need to be replaced after several uses.
Aug 24, 2008 | Office Equipment & Supplies
Panasonic DP-1810P Laser Copier
The copier has an "eye" that detects when the waste toner bottle is full. If you dump it and reuse it, the residue can build up and cause the machine to "think" the bottle is still full. I experienced the same problem. If you re-use an old bottle, after emptying, rinse our any remaining residue and dry the bottle out. Your copier should then notice the bottle being empty.
Mar 14, 2008 | Panasonic DP-1810P Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
491 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
