Question about Philips 55PP9401 55" Rear Projection Television
Screen missing i was transporting a phillips magnavox 55 inch projection tv. it appears i lost one of the screens because when we arrived i turned it on and the screen is almost transparent form the side i can see the picture but looking straight on i see the 3 lights inside shining bright. i was wondering a cheap easy way to solve this problem. dave b ..pittsburgh
  • Philips Master
  • 8,617 Answers
You will need the replacement screens. Phillips doesnt make them anylonger, they are exspensive. But you can get one by leaving a email at the following link with the model number of your set and what youre needing.
http://servicemanuals.vstore.ca/
Posted on Jul 14, 2008
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
Red "aura" in the middle of my 55" Phillips Magnavox
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 60inc phillips magnovox has poor color, what do i have to do?
we just bought a 55 inch phillips magnavox and told it was working fine when we got it home and turned it on it was a red screen and was really foggy. we looked up some tv repair places and ONLY 1 told us it was the picture tube and to look down them with a flashlight for bacteria! sure enough the green and blue had it. so we found one place that would sell us the coolant fluid that you have to change the others could get it in or wanted us to bring the tv to them. we did it our selves the stuff was $17.00 a bottle or if we took it in it would be about $375.00. we have a great picture now and it wasn't as hard as all the other repair places said.
Dec 28, 2008 | Philips Magnavox 9P6034C 60" Rear...
60 inch fresnel screen
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Dec 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a 10 year old phillips magnovox 55 inch tv
yes you can take off the cover but carefuly and in the back of your tv you will see the flyback and has 2 button one fro focus and other G2 then rotate the focus button till you will see no blurry
that is all if you dont know how bring some frend who can and tell him to do that
Dec 10, 2008 | Philips Magnavox 55P9271 55" Rear...
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email slinteriors@yahoo.com as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
NEED USED SCREEN FOR PROJECTION TV
I have an 9P6040C101 that i am selling off parts.
I did sell the mesh screen, but i have the protection screen and everything else.
443-255-1892
Oct 19, 2007 | Philips Magnavox 9P6034C 60" Rear...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
