Question about Nintendo Wii Console
Wii eject button broken
The eject button on my wii won't hit the switch; I can press it, but it won't do anything and it doesn't feel like the button in pressing anything. Is there any way to fix this or do I have to send it to nintendo?
  • latinscholar Aug 16, 2008
    where can i get a wii triblade from?
Open it up. get a Wii triblade tool for $2 and open it. just unscrew the face plate, shift the button so that it will hit the button again, and screw the faceplate back on. Wont void warranty.
Posted on Jul 30, 2008
Will not eject disc
try this 1st
"Turn the Wii off with the Wiimote (so that it completely powers off and is not active). then hit the eject button"
and filing that that you need to remove the front panel and there is a manual paper clip button......it sounds like the button is broken
how to here
http://www.consolezombie.com/Wii/Wii-Case-Opening-Tutorial.html
hope that helps
Aug 22, 2011 | Nintendo Wii Console
Will not eject disk
Is your eject button broken? Does it click when you punch it, or goes in like the button on the board is broken?
It is either this or there is something jammed inside your system.
Video: How to open Wii Console
Check inside your drive and remove anything stuck in there causing the drive to not function correctly when ejecting.
Hope I helped!
Take care
May 09, 2010 | Nintendo Wii Console
Game will not eject. I've tried disconnecting power & still nothing. The Wii still plays the game disc fine.
Hope I helped!
Apr 12, 2010 | Nintendo Wii Console
I have a brand new game stuck in my wii console how do i get it out
1.Make sure the WII is stood up properly.
2.Then switch on the WII
3.Now look near the eject button...
- Look at the right top bendy bit of the eject button put your nail through it and press it down it should eject.
- If still not ejected after several seconds holding, disconnect all the cable's in the WII leave it for a while (approx 5 Min) and plug it back in, switch on the WII, then press eject.
- If it does not come out look inside the drive and see if the disk can be physically pulled out now.
Mar 25, 2010 | Nintendo Wii Console
Wont eject the game
Unplug it, then press and hold the eject button. While holding the eject button down, re-apply power and turn on the unit. If the unit senses the eject button pressed, it should eject anything in the drive.
Feb 11, 2010 | Nintendo Wii Console
Disc is stuck inside goes on will not eject or
You will find a small whole in front of the disc. Quite small, say a niddle head size just take a pin approx 3 inches and poke it slowly inside. You shall feel the pushing of a soft touch feather button like on your keyboard and your CD will come out. Don't forget to push eject button before poking the pin. and kindly do rate my solution.
Jul 17, 2009 | Nintendo Wii Console
Disc won't eject.
When you hit eject do you hear it attempting to push out the disc? It may be blocked by something. If it is not attempting to push out the disc then something isn't registering with the eject button. In this case, power down the wii, unplug all plugs from the back, wait 90 seconds or so, plug in just the power plug and hit the eject button (before hitting power or anything else). If it still does not try to eject then either the button is broken or the disc drive in the wii has died.
It is still probably under warranty from Nintendo, they can fix it for free for you. If anything, give them a call at:
1-800-255-3700
Jun 25, 2009 | Nintendo Wii Console
Disk will not eject
Maybe because the eject button is off the micro switch and you need to either press it hard or get a wii professional to take off the eject button and replace it to where it will touch the micro switch.
Oct 27, 2008 | Nintendo Wii Console
Nintendo Wii console gets a black screen when switched on
not to be mean but buying a modded anything usually voids the warranty.
Not having anything to go off of regarding the mod means that we don't know if it's a faulty weld on the board or anything like that.
Try doing a system reset (if there is a reset button) and see if that works
Jun 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
1,323 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
