Question about Whirlpool LER5636P Electric Dryer
Dryer won't turn on - interior light on
I have a 6 year old dryer that will not turn on... the drum doesn't turn, but the interior light is on. I have checked the fuse box, unplugged and replugged the dryer and it won't come on. The timer runs when turned to a timed setting, but when I press the button to turn it on, it does nothing - no sound, no starting.
  • jwags83 Jul 10, 2008
    Thanks for the response.. The door switch does not seem to be the problem as the light goes out. The motor appears to try to run... now I think it may be an electrical problem... from the outside. With the dryer unplugged, I disconnected and reconnected all the electrical contact points to the heater element, the drum motor, and everything else visible. I put it all back together and it started running, however the belt sounds like it is "rubbing" or "squeeking" and the dryer wouldn't start up again after a full cycle. I repeated the process and again it worked for one cycle. Could the belt be bad? or the motor? or would you suggest an electrical issue? Following four days of vacation, I experienced the same thing... disconnect the electrical points, reconnect and it works for 1 cycle, then when you start it, the motor acts like it is trying to turn, but just can't start.... This is with clothes in the dryer... when empty the drum starts to turn. Again, now I think it is a power issue --
  • 5,911 Answers
It sounds like you have either a broken drum belt or a door switch that isn't working. If the dryer belt breaks, the drum will not turn, but you will probably still hear the motor running. I don't think your model has a broken belt switch that disables the motor (at least I couldn't find one). You didn't mention anything about hearing a motor running, either. The likely cause, then. would be a door switch. If the switch was not making contact when the door was closed, it would give the very same symptoms you described. Have you tried pushing on the switch with the door open to see if the drum light goes out? If the light DOES go out, we probably have a primary power problem to the drive motor. If the light DOES NOT go out, replace the door switch. You can find the part at searspartsdirect.com. Just type in your model number and you can locate the switch under the "Cabinet Parts" heading as item number 10 (part #3406107). Let me know how you diagnose this and get back to me. If it is the switch, I can give you steps on how to replace it. If its not, then we'll have to troubleshoot a little further. I'm trying the simple approach first before attempting to disassemble the dryer. I hope this helps you.
Posted on Jul 03, 2008
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
When start button pushed, motor tries to start turn, won't turn, shuts off after about 5 seconds. It's a whirlpool modle LGR7646eqo gas dryer, several years old.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Apr 19, 2011 | Whirlpool LGR7646E Dryer
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
Eleven year old Whirlpool electric dryer cannot turn the drum with a full load of towels. The motor turns on but then shuts off. It will turn a very light load.
Turn the drum by hand. It should rotate fairly easy in one direction. If so, then the motor is going out and need replacement. Fairly common problem.
Jul 13, 2009 | Estate TGDS840JQ Gas Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Dryer running loud
It sounds like your motor may be going out (search for motor replacement solution here).
Hopefully it is just a problem with grit in the system, or perhaps the felt gaskets have worked themselves loose. Either way, to clean out grit and inspect the system you'll need to access the interior and remove the drum. Here's how:
  1. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
Now: Maintenance time!
  1. Using compressed air blow out all vents and the motor.
  2. Wipe dust and grit out of crannies
  3. Vaccuum bottom interior
  4. Blow it out again
  5. Using ultra fine steel wool (#0000) rub all contact areas of drum - belt region, and ends that contact the felt gaskets and the rollers at the rear
  6. Check to ensure the felt gasket is in good shape all around the drum contact area. If it is torn, malformed or missing you'll need to replace. With any luck this is where your noise is coming from.
  7. Check the blower cage. Ensure this is free of grit. It is worth taking off the eight screws to wipe out/blow out interior.
  8. Worse case scenario - your motor is on the fritz (although this motor should give you 8-12 years of service). This will require removal, replacement. Motor cost is about $100. Labor will be more.
Aug 04, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Whirlpool LER5636P Electric Dryer Logo
187 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
