Question about Evenflo Snugli Front & Back Baby Carrier
I can't figure out how to convert my snugli from baby facing inward, to baby facing outward
  • kabrady Jul 12, 2008
    I am having the same problem. I can't seem to figure it out. Someone please help!
  • Anonymous Oct 17, 2008
    I was given a Snugli without the instructions. Instructions for this model don't seem to be available on the Evenflo Web site. The label with the model # doesn't look the same as the one they use as an illustration, and so I'm not sure what to enter on the form. Help?
If you are using the same one that I have...you put it on the same way as if the baby if front facing against you instead you place the baby outward and the piece that would normally support their head folds down in half away from you and the 2 straps that supported the head now holds that piece folded down and gives the baby added support when you lean forward. I hope this helps if not post another problem and I will try to explain again. Good Luck...
Posted on Oct 22, 2008
I went to this website:
https://plweb.evenflo.com/replacement_parts.aspx
typed in the model number and manufacture date (both are on a label on my Snugli), and a pdf of the instruction manual came up, which gives directions on how to convert it. Hope this helps!
Posted on Aug 03, 2008
2000 Nissan Pathfinder struts. The Haynes manual says that the notch in the upper spring seat is supposed to face outwards. The notch on the strut I removed was facing inwards. Which way is correct?
I know, right. I had the same problem using the Haynes manual when I replaced mine on my '97 4WD Pathfinderl. With the notch facing away from the vehicle, it does not look right, because the angle of the upper seat does not match the coil spring winding angle. I didn't take note of the location of the notch prior to removal. I still installed the upper spring seat with the notch facing outward per the manual. I still wonder if this is correct. What have you found out?
Aug 21, 2010 | 2000 Nissan Pathfinder
Broken locks on the handle
You can call perego at 1800-671-1701 they will help you.
Oct 01, 2009 | Baby Gear
Need instructions on how to strap baby in rear facing in Evenflo Snugli Comfort Vent Soft Carrier
typed in the model number and manufacture date (both are on a label on my Snugli), and a pdf of the instruction manual came up. Hope this helps!
By avatar8.jpgterraplnr Aug 03, 2008
Sep 12, 2009 | Evenflo Snugli Comfort Vent Baby Carrier
No date of manufacture on my snugli
is it possible that your PO number stands for produced on number you may be able to use that as the manufactor date
on my snugli you put the baby in facing out and you fold the top of the front down and buckle it where youwould for the head support if they were facingin hope it helps and if it does can you leave me a good rating thanks
Aug 21, 2008 | Evenflo Snugli Front & Back Baby Carrier
Purple legs
Which way is she facing? I have a 9 month old baby boy and this doesn't happen, and he is a little hefty! I am wondering if your lower straps are too tight. If she is facing forward, does she lean forward having the material cut into her legs? Maybe that causes the circulation loss. I always have my son face inward. He likes it more and it is more natural.
Jun 30, 2008 | Baby Bjorn Active Baby Carrier
How to install graco seat in 99 jimmy
i think the snug rides are rear facing only. if it pulls out of a base and has a carrying handle. its rear facing only.
Mar 02, 2008 | Graco SnugRide - Clover
Front carrier to back carrier
Feb 03, 2008 | Evenflo Snugli Front & Back Baby Carrier
Change
Dec 09, 2007 | Evenflo Snugli Front & Back Baby Carrier
Evenflo Snugli Front & Back Baby Carrier Logo
1,121 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
