Question about Dell E207WFP LCD Monitor
Please help my monitor!!
The screen was placed screen side down on an object and it looks like it got cracked internally is there a way I can fix this? Here is a picture I hpe it helps in narrowing down what part I could possible replace.
  • 191 Answers
Generally say it is LCD panel broken and have to change the same model LCD panel (see the lable on back of panel). there are some other model can be compatible acording the same panel version, no mater manufactory
Posted on Feb 07, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
How open va1903wb?
If there are no screws on the rear side to hold it together, the unit will be basically held together by internal latches. If so, then remove the base stand and screws. Then place the unit on a flat surface. Begin at the top side and curl your fingers and press against the edge of the front bezel lip area. With upward force, pull up until you hear a snap sound and the front bezel separates from the rear cover. Do this all the way around until the front bezel is completely separated from the rear cover. Then flip the monitor over face down onto a soft towel. Avoid any object under the screen to prevent scratches or nicks. Then carefully remove the rear bezel.
Jul 22, 2014 | ViewSonic VA1903wb (Black) Monitor
My ematic eBook screen internally cracked how can i fix it?
There are places online where you can get a replacement screen if you're not afraid to take your e-reader apart. Otherwise look for a local repair shop near you.
Jun 17, 2017 | Ematic 7" Color EB105 eBook Reader...
How do I hook a an external monitor up to a hp dv6 1355 with a cracked screen?
http://h10025.www1.hp.com/ewfrf/wc/product?product=4043282&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Product specifications;
External Ports:
1 VGA (15-pin)
Manuals > Notebook Tour - Windows 7;
Left-side Components - External Monitor Port
Left/Rear side of laptop,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
(You can also use an HDTV if it has an HDMI port, and you have an HDMI cable. The HDMI port is on the Left side of the laptop, too.
{Don't buy an HDMI cable that is expensive. Just a waste of money.
Those gold plated parts are just a little bit better, than an HDMI cable that doesn't have it. $20 for an HDMI cable is PLENTY. (12 Feet) I use one's that cost less )
A) Laptop OFF, monitor (External display device) OFF.
Connect the VGA monitor to the VGA port, on the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There ARE at least 3 display options available;
1) Internal monitor ONLY
2) Internal monitor AND external display device (VGA monitor in this example)
3) External display device ONLY
Press, and hold the Fn key down, tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
Wait a few seconds.
Still no?
Hold the Fn key down again, and tap once more on the F4 key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 15, 2012 | Computers & Internet
Cant use camera
internal ribbon cable grounding itself out. open it up and seat all ribbon cables snugg. beware thou the capacitor that charges the flash can shock the heck out of you and leave a nasty burn. you have to short ground the cap with a metal object that has a rubber handle. if this doesnt fix the lcd is cracked.
Jun 02, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
May 29, 2009 | HP w2207 Monitor
PSP internal screen cracked!!!
I recommend seeing an expert. I heard that to replace the internal screen only costs about 20 dollars if you do it yourself. You should look into buying a new screen(internal) but about the leaking LED's you should really try to see an expert or get some support from Sony.
Dec 21, 2008 | Sony PlayStation Portable (PSP) Console
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Crack screen
hi jenla,
Sharp televisions have a few layers of plastic before getting to the actual screen, these are very cheap to replace, and they just require you to take the cracked one out and replace it.
However, if the picture is affected, then it will cost alot to replace the screen, hopefully you have warrenty, you may want to replace the tv itself
Dec 31, 2007 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
Green screen
From your lines... 'Tapping the side of the monitor' Reminds me cracked solder joints. You need to check for this.
First open the Chassis and narrow down the area of the circuit board where exactly applying force makes the monitor fine and in that area of board / around that area look for cracked solders. Definitely this will help you.
May 30, 2006 | HP Pavilion M70 17" CRT Monitor
Dell E207WFP LCD Monitor Logo
76 people viewed this question
Alun Cox
