Question about Motorola Mobility RAZR V3
Razr will not allow me to answer call if the flip is open, on/off button still works
Where are the flex cable connections? When I press all keys except the on/off this message pops up "voice record memory full". The on/off key still functions by clearing missed calls, etc. I do not know what caused this to occur.
    Brigadier General:
  • 7,752 Answers
If you are planning to remove the connecters which are located on the lcd and main-board you should not play around with it unless you are comfortable taking apart the phone...so you should take the phone to a mobile service center and have them fix the phone for you.
Posted on Jul 05, 2008
The phone works, recieves and makes calls but both screens are dead???? verizon motorola razr v3
How about the buttons next to the screen? If you do not hear anything when you press those buttons, it is going to be the flex cable. The flex cable connects the phone between the hinge. It connects the 2 displays (it's really one display part with both screens, it has a screen on the front and back).
Basically you have the most common problem with the RAZR, the screen part connects to the bottom via the flex cable and is partially damaged or has ben severed. Not terribly hard to fix but you would need someone who can take it apart and who can get the part as well.
Oct 23, 2009 | Motorola Mobility RAZR V3
New razr v3
chane the flex cable or try and reflash the phone firmware.
Dec 06, 2007 | Motorola Mobility RAZR V3
Buttons don't work
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Nov 26, 2007 | Motorola Mobility RAZR V3
Ringer turns off when I don't want it to!
To the best of my knowledge there is no way to disable the feature...Sorry...
Oct 11, 2007 | Motorola Mobility RAZR V3
Frozen buttons except red end call button
Sep 22, 2007 | Motorola Mobility RAZR V3
Motorola razr
YOU NEED TO FLASH A NEW FLEX VERSION. TRY TO TURN ON YOUR MOTOROLA BY PRESSING * # AND RED KEY AT THE SAME TIME TO GET IN BOOT LOADER VERSION. YOU ALSO NEED THE USB CABLE THAT CONNECTS MOTOROLA AND PC THEN DOWNLOAD THE FLASHBACKUP PROGRAM. ABOUT THE FLEX VESRION DOWNLOAD THE FILE FROM MOTOX SITE. BUT FIRST WRITE DOWN THE BOOTLOADER, THE FLEX VERSION ALREADY HAS AND THE S/W VERSION SO TO CHOOSE THE RIGHT FLEX.
Sep 03, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr - Keypad Doesn't Work
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Jun 25, 2007 | Motorola Mobility RAZR V3
Keypad frozen, still receives calls
Hi, You don't need 2 flash your razr for this problem. What u need is a screen flex cable. The three buttons around the screen are controlled by a flex cable and the voice recorder is connected on this flex cable.This needs replacing but it's very tricky to deal with. I suggest a really good tech that deals with razr's to handle this problem to possibly replace the flex cable. This would solve yor frozen keypad problem. SAM !
Jun 19, 2007 | Motorola Mobility RAZR V3
Motorola key board does not light up when it is flipped open
you have to change the flex cable(ribbon).take it to a technician
Feb 10, 2007 | Motorola Mobility RAZR V3
Broken phone!!
Saw quite a few of these. Have you tried taking the battery and Sim out while the phone is still on? did you try to flash your firmware on your Razr? there is one firmware will mess up your keypad, but all you have to do is apply keypad flex and it will work again. A friend recently updated his firmware and had to re-apply flex, works fine now. Good luck!
Jun 09, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
