Turn Off Power Save Toshiba eStudio 150
How can I turn off the power save mode on my
Toshiba eStudio 150 copier. I have the time maxed out
but it is still annoying. Any secret codes?
  • Anonymous Mar 13, 2014
    I have a new Ricoh MP 9002 and it has Sleep and Power Saver buttons. It only allows 60 minutes max for the Sleep function and then it goes into power save. Once it is in Power Save, it takes 5 minutes to comb back up. This is very inconvenient if you need something in a hurry. Is there a way to disable the Power Save?
  • 53 Answers
Don't know if this applies to Toshiba but Xerox machines have the same annoying problem, which is NOT fixable.Xerox machines are used in the EEC who insist that power save is not resettable only able to be set to 120mins max Gotta save the power y'know!
Posted on Jul 19, 2008
look for energy save and either switch it off or increse the time to the max to prolong it entering power save mode
Jan 27, 2014 | Sharp Office Equipment & Supplies
Can you turn off the power save mode for this device? If so how do you do it.
The power saver mode can not be turned off. This feature is designed for you to save energy on power consumption and reduce impact to the environment. You can easily adjust the time on when you want the power saver mode engaged. Press Setup > Device Setup > Power Saver. You can set it to activate after 240 minutes at most.
Sep 24, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
you need to go into the additional functions setting and change the power save setting to 4 hrs... it won't shut of and go into power save mode unless it hasn't been used for 4 hrs strait. i don't belive there is a way to turn the power save mode off completly that is the best you can do.
Jun 21, 2010 | Canon imageRUNNER 5000 Copier
Toshiba E Studio 35 copier goes to power save
Hold down the 0 and 8 keys while turning on the copier. Keep on holding down the keys until the screen shows a adjustment mode screen. Once it does this key in 205 then you should see a numeric value. Input 15 and press start to lock it in This will change you power saver mode to 60 minutes. Next enter code 206. Key in 19 and press start. This will change your sleep mode to 240 minutes. These are the setting that are most generally used when these copiers are initially set up. Then just turn the copier off and back on. I hope this resolves your problem.
Good Luck
Mar 13, 2009 | Toshiba e-Studio 35 Copier
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
Jan 24, 2009 | Gateway 506GR PC Desktop
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Monitor keeps going to power save mode
the settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
Sep 26, 2007 | Toshiba (K000006610) for Satellite P25...
Toshiba eStudio 211c
it is hard disk trouble. First enter in service mode (pressing 08 while turn on the power) next, type 690 and set to 2, click enter and wait the "reboot the machine" message, then turn off and on again
Apr 11, 2007 | Toshiba E-STUDIO 211C Copier
460 people viewed this question
