Question about Symbol LS2208 Handheld
LS2208-SR20007R-UR - USB connections - Red Laser Light going out
We just purchased 18 LS2208-SR20007R-UR with the USB connection. Right off the bat we have 6 that do not have a Red laser light. Is there a fix for this or do I need to replace these?
Get the LS4208. they are much better
Posted on Aug 11, 2008
How to program a bar code scanner to have 3 "TAB" in prefix
In the appropriate manual (see link)
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Go to the proper symbology page scan the prefix start then find the tab character and scan it three times to add the prefix then scan the complete barcode for the prefix
May 16, 2016 | Zebra LS2208-SR20007R-UR
Hello I have trouble with laser ls2208 it is PS2 connection but i have only USB on PC so i buy converter ps2 to usb but after connected scanner read product but not send text to pc .
You can try scanning the Keyboard Wedge host type barcode IBM AT Notebook then rebooting your PC. If this does not work you should order a CBA-U01-S07ZAR. This is the USB cable for use with the LS2208. Zebra Technologies support solution ADC-00217 addresses this type of issue. The article was written for connecting to a laptop, but your connection is similar if you do not have a keyboard attached to the cable. This link will take you to the solution which includes the IBM AT Notebook barcode. portal motorolasolutions com Print the article and scan the barcode then reboot your PC.
Dec 11, 2014 | Symbol LS2208 Handheld
Hi my name is christian canola and i purchased a symbol ls2208 barcode scanner from geminicomputers and i downloaded the program 123 scan2 for my barcode scanner and i click on my scanner is connected via...
Hi Christian, if your scanner was manufactured before February 2010 it may not be able to communicate directly with 123Scan2 so you wont be able to upgrade firmware with the program, but you will still be able to use it to create configuration sheets. These are the only two uses for 123Scan2.
To create a configuration sheet without "finding" the scanner click Create New Configuration then choose My scanner is NOT connected. Select the LS2208 and click on the blue firmware button to get into the configuration. When you have completed your configuration click the Print bar codes selection at the top of the window and when the file comes up be sure to click on the Bar code formatting menu and change the Bar code type to 1D One setting per barcode if it is not already there. Older scanners will not work with concatenated 1D barcodes where 123Scan2 puts more than one setting into a barcode.
Feb 12, 2011 | Symbol LS2208 Handheld
Dear sire I have symbol LS2208 handheld scanner (serial cable) but when connected in com port in a regular PC it do not power on .
you're going to either connect it to a com port that provides power, or get a different cable that allows you to connect an external power supply to it.
CBA-R01-S07PAR RS232 Cable assy, 50-14000-009R 220V PS,
or get a usb cable - program the scanner to USB, This will provide the power.
CBA-U01-S07ZAR-B
but only if you have an operating system that recognizes USB
Sep 23, 2010 | Symbol LS2208-7AZK0100S Handheld
LS2208 displays no light
If the scanner is on a USB extension, they can be underpowered and will show up in the device manager but not work. This device like to be connected to a USB cord no longer then 4 ft or so.
Feb 23, 2010 | Zebra LS2208 Handheld Barcode Scanner
I have a Symbol LS2208 barcode scanner with an RS232 connection. My new computer only has USB. Can I simply buy a new cable for the scanner, or do I have to get a serial-usb adapter to make it work?
You can purchase a USB cable for the scanner. The cable comes out of the handle of the scanner. The part number of the USB cable is CBA-U01-S07ZAR.
Sep 05, 2009 | Symbol LS2208 Handheld
LS2208 works - Keyboard does not
Check that the wedge is good. It is basically a hybrid spltter that powers both the scanner and the keyboard.
USB keyboard?
If so, you may want to go direct to either a serial port or a USB direct connection
Feb 24, 2009 | Symbol LS2208 Handheld
SCANNING PROBLEMS
We are major Symbol/Motorola dealers...I can help. I don't understand your question. (By the way, by changing the cable on your keyboard wedge models, you can also use them on the USB ports. Give me a call at 1-866-306-7226, or you can also contact the Help Desk at 1-800-653-5350
Cheers.
Bill Matisz,
qdata inc.
Edmonton, AB
Mar 03, 2008 | Symbol LS2208 Handheld
Barcode scanner won't scan.
You are likely experiencing power sag. If you are using a 15 foot usb cable try a 6 foot one instead. Even if that doesn't work it still could be power sag.
We sell an external power cable kit that replaces your USB cable with one that includes a power pack on the computer side.
The power pack provides the extra power you need.
It happens when it does becuase when the laser comes on more power is needed than available. The 5 VDC sags and the processor whigs out on you.
Dec 05, 2007 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
1,148 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
