Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
Hotkey problems my hotkeys don't perform the assigned fucntion, they do something else!
  • Magani Nov 09, 2008
    I've just reinstalled a one-year-old Logitech MX Duo and now find that the only keyboard 'enhancements' that work as advertised are the volume control and the scroll wheel at the left side of the keyboard. When I press :-
    'My Home' button I get Favorites;
    'Favorites', I get a 'Media Centre' popup;
    'Shopping' I get a Logitech help screen for Keyboard Quick Reference;
    'Search' I get the Windows Messenger logon screen;
    'iTouch' I get the Master Volume at the bottom of the screen;
    Mute button gets me the iTouch/Standard F-Key Functions;
    'Webcam' it does the Play/Pause operation for Media Player;
    'Messenger/SMS' stops the Media Player;
    'E-mail' selects the Master Mute option
    'F-Track' select Next Track on Media Player.
    I think I'm losing what's left of my mind. :-(
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Posted on Nov 09, 2008
How do I turn on my hotkey utility V21.5
There is no Qliner utility V21.5. There is not ever a V3.0, to my knowledge.
I am not certain what type or how your laptop is configured, but it probably had keys already assigned for connection to the internet. If you installed a Qliner utility and rebooted, the key combinations may have been reassigned to those of Qliner. At that point, see if pressing the Windows key plus the Z key will pop up a keyboard. There are some links offering tutorials for use of Qliner. However, the page does not allow downloading of Qliner, available elsewhere. If you can not get it working, it probably begs uninstalling and maybe even going back to a system restore point to recover the original hotkey assignments for your laptop. Qliner's installation appears to have options for a number of modules allowing building special command sets, I believe.
http://www.qliner.com/hotkeys/overview.htm
Oct 11, 2014 | Qliner Hotkeys
On-screen keyboard problem
I think you might have your Hotkeys on, try disabling them
Hotkeys will only work while the SmartNAV software is running. Keyboard keys assigned to Hotkeys will not perform their normal keyboard function while they are being used as Hotkeys. For example, if the CAPS LOCK keyboard key is assigned to Left Click, it will only perform Left Clicks while the SmartNAV software is running. It will resume performing the normal CAPS LOCK function when the SmartNAV software is closed, or if the Hotkey is re-assigned or disabled.
please see the following link for more info
http://www.naturalpoint.com/smartnav/support/manual/sn-Chapter_4.html
May 12, 2008 | Apple MacBook Pro Notebook
Tip
Create a Shortcut or Hotkey to Eject the CD/DVD Drive
Create a Shortcut to Eject the CD/DVD Drive
Right-click on the desktop or elsewhere and choose New \ Shortcut.
In the location box, put the full path to the nircmd.exe file that you downloaded, and append the "cdrom open" command to the end of it, adjusting the drive letter to match your disc drive:
"C:\path\to\nircmd.exe" cdrom open D:
Note the location of the quotes.. if you are using a path with spaces in it, you need to make sure the quotes are only around the path to the executable, and the arguments should be placed after the quote.
Give the shortcut a meaningful name, like Eject CD or something like that, and you'll have a new icon (read below on how to use the cd-rom icon as shown)
Create a Shortcut to Close the CD/DVD Drive
You can follow the same exact instructions as above, but instead of "cdrom open" just substitute "cdrom close".
Assign a Hotkey to the Shortcut
Now that we have a shortcut, we can assign a hotkey to the shortcut by right-clicking on the icon and choosing Properties. On the Shortcut tab you'll see a place to assign the Shortcut key:
on Apr 29, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Ive lost my hotkeys on my keyboard
Sounds like your keyboard driver has either stopped working or has been removed. Keyboards will function as normal without specific drivers but hotkeys etc. wont work. Look at the manufactures web site for keyboard drivers, usually they are pretty good at providing the downloads. without them installed correctly hotkeys will not work. Once installed run the software and check the keys assignments.
Nov 24, 2013 | Computers & Internet
Packard bell easynote hotkeys don't work after reinstall windows 7
Well it seams you did not download the software for the hot keys.
Oct 03, 2012 | Packard Bell Computers & Internet
I'm playing a game that uses tab key a lot. The dvd hotkey is right next to the tab and it tries to load that over my game. How can I disable that hotkey. The program came with the computer and I...
Uninstall the hotkey software from Control Panel (Add/Remove Programs in XP, Programs and Features in Vista, 7)
Alternatively install Startup Control Panel and uncheck the program from startup.The program works great in XP, for Vista and 7 there is more playing around:
  • Download the zip file
  • Click Extract All files
  • Right click on the program
  • Choose Run as Administrator
  • Install the program
  • Open Control Panel and choose Classic View
  • Run Startup
  • Uncheck something in HKLM and it will duplicate
  • Close Startup
  • Wait for Windows to pop up a box
  • Click Reinstall using recommended settings
  • Allow the program to run
  • Now you can remove the programs from startup.
  • Restart your computer
Jul 23, 2011 | Computers & Internet
Hotkeys blocked
If the hotkeys on a laptop for example, are not performing their designated functions, it may be a good idea to reinstall the drivers that come with said laptop, they are usually found on discs included in a laptop's packaging, this is because when these drivers are not installed, Windows will not recognise them, and either ignore commands from them all together, or perform their alternative function.
One can download the Panasonic Toughbook Hotkey Drivers from this webpage...
http://pc-dl.panasonic.co.jp/dl/recent?dc%5B%5D=002001004
Mar 07, 2011 | Panasonic Toughbook CF-51 Notebook
Is it possible to assign a hotkey in microsoft word? I currently do transcribing and would like to assign people's names to a hotkey for each new file I do?
Yes you can asign hotkey in microsoft word. Please check the article bellow which would help you doing it.
http://office.microsoft.com/en-us/word-help/assign-shortcut-keys-to-your-favorite-word-features-HA001042965.aspx
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 18, 2010 | Microsoft Windows? Vista Home Basic...
Changing hotkeys on microsoft ergonmic 4000 keyboard
The manual says to go to "Start->Programs->Microsoft Keyboard->Microsoft Keyboard", and from there you can edit the key settings.
Oct 07, 2007 | Microsoft Natural Ergonomic 4000
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
258 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
