Question about Emerson Fans Emerson SW375 Receiver
Only off and high speed
I have the emerson cornerstone 1895 with a 6 speed remote hand-held control and receiver. I think it the sw375 reciever thats bad, because I get a mmentary hum and motor twist, but the fan won't continue to spin at any lower speed. I get operation at high speed, but can't get a lower speed to stay constant. The fan is ony operable at high and I'd wish to know what part needs replacement. Is it the receiver that is bad, or is it the capacitor?
  • dmh313 Aug 18, 2008
    I also have an Emerson fan with the SW375 control unit. My fan will run at the very lowest speed and the very highest speed but nothing in between. If you turn it on a very lowest speed and then try to increase speed on the remote unit it will jump to the very highest speed even though indicater lights on remote unit show intermediate speeds. Is my SW375 bad?
2 Suggested Answers
SOURCE: Emerson CF4800 with SW375 receiver that does not turn on fan!
Please excuse me if you already have the answer, but I went thru the same thing and found that the actual receiver was broken. The receiver that is found in the top part of the fan itself. I was able to diagnose the problem because I have two of the same fans in the house and when I switched the receiver units, the broken fan started to work. Hope that helps.
Posted on Dec 18, 2009
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
Emerson SR330 remote not working
1) Test the wires inside from remote control, could some wires is loose you need to solder.
2) Clean the contact batteries with special spray contact cleaner.
3) Retight the spring contact batteries for better contact.
4) After you did all this , if there are NOT function you mus open the remote and resolder any point for cool solder.
5) Otherwise you must reset the remote and put again the code go www.fitness.manualsonline. com or www.remotecodelist.com and download for free.
sincerely. God bless you
May 08, 2012 | Emerson SR330 Remote Control
I just moved into a house with a Hunter ceiling fan only controlled with a hand-held remote controller that has 2 speeds: OFF and HIGH. How can I adjust this fan to a lower speed?
If the fan still has a pull chain on the side of the motor housing, you can use that to change the speeds and/or turn it it OFF or ON. If it has 2 chains, one is for the speed control and the other is for the light fixture, it is so equipped.
Hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Heating & Cooling
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or...
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Sep 15, 2010 | Hunter 52" Ceiling Fan With Light And...
HAVE AN EMERSON FAN WITH REMOTE ONLY THAT I CANNOT CHANGE DIRECTI
First, tell us the model of the fan as well as the receiver and remote?
Can not solve a answer without a thorough question...But I am willing to help.
Apr 08, 2010 | Emerson Fans Emerson SW375 Receiver
May 30, 2009 | Emerson Fans Emerson SW375 Receiver
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Emerson Fans Emerson SW375 Receiver Logo
Top Emerson Fans Dryers Experts
Are you an Emerson Fans Dryer Expert? Answer questions, earn points and help others
