Question about Samsung Televison & Video
HL-R56667W 50" LCD HD TV stopped working. Keeping powering on and off when plugged in. No more picture.
  • 3 more comments
  • jhuerena Jul 03, 2008
    Just wanted to note that when it's plugged in I get a loud buzzing/hum-type noise.
    NS,
    Where are the fuses located? I didn't see them when I took the back off.
    From the back, hum comes from area to the left of the bulb.
    HL-R56667W HD TV stopped working. Keeping powering on and off when plugged in. No more picture. When it's plugged in I get a loud buzzing/hum-type noise from the back, hum comes from area to the left of the bulb.
    Replaced bulb yesterday. Problem still exists.
  • 4,234 Answers
The buszzing you are hearing is coming from the "ballast" portion of the set. This is the part that "fires" the lamp. It is possible that the lamp is faulty and causing this. If you have a spare lamp, try that. It is possible that the ballast is bad. The cheapest way to try and isolate the problem is to replace the lamp with a known good one.
Try that and let me know if that helps. In the meantime, I'll look for other clues for you to look for.
Dan
Posted on Jul 03, 2008
  • ABRsvcs Jul 03, 2008
    Forgot to add. The set powers down as protection. There are circuits inside that cause this to happen and this is normal when a problem occurs. The idea is to prevent further damage to the set.
    Dan
    Unfortunately this is not a problem that lends itself to remote diagnosis. You may have to get a detailed repair estimate for this one. We can guide you through the actual repair, but without taking some measurements, it is dificult to diagnose.
    Dan
    Sergeant:
    Champion:
  • 417 Answers
Its shorting out on you it may happen because of a blow fuse i think you may need to check the fuses inside the tv witch takes time
  • 1 more comment
  • nicholas Rokkasarno
    nicholas Rokkasarno Jul 03, 2008
    they should be located were the power cable starts from
    buzzing noise the ok now i know whats wrong there a fault inside the projection tv if you could tell me were about the noise if coming from can tell you what it is
    ITS A AIR BREAK ITS NEED TO BE PROFESSIONALLY LOOK'T AT
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Nov 09, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
No sound
There are two quick things to try:
1) The TV's speakers may be turned off. To turn on: Press MENU, select "Sound Settings", select "Internal Speakers", then select "On" (as opposed to "Off"), and then EXIT.
2) The Sound source may be set to PIP (picture in picture) instead of Main picture. In that case press MENU, select "Picture", select "PIP", select "Select Sound", then select "Main" (as opposed to "Sub"), as the source of the sound, and then press EXIT.
Whatever PIP is set to may not even be connected to the TV so there would be no sound.
The terms and menus used here are from Samsung so they will be different from yours but the concept is the same.
Good luck,
Techjoel
Apr 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
No controls
this should be easy to fix. The first thing is to check the buttons. Make sure that the buttons ar not pushed in and they work. What I meen is that when you push a button make sure it makes a cliking noise when you push it and releas it. If it dose not that is your problem. If they all work, Unplug the tv for 30 min. then plug it back in. It should work after that. If the remote dose not work after unplugging the set, you may have internal problems
Mar 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
