Question about HP Scanjet 7800 Pass-Through Scanner
Feeder The feeder pulls in all the paper at once instead of one by one
  • 43 Answers
Hi
the scanner will do that sometimes, it's easiest to just feed the pieces through one by one when that happens.
Regards Liz
Posted on Feb 22, 2010
Paper feeder grabs several pieces of paper at once
The spot in which the paper is fed into could have a fence/blocker. Use wood or a little hunk of aluminum to only allow 1 sheet. You could get fandy and use a rod that could also be mounted on the font.Be crea8tive and good luck.
Jul 21, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Canon Imagerunner 3230 - The Default Settings for Paper Source are set to pull paper from the side feeder tray instead of Auto when printing EMAILS (only). Everything else prints fine (the paper is pulled...
If you go to the printer properties before you send it to print you should be able to choose which tray to print from. Or you can set the default tray in the print driver and then apply it to set it in as default.
Jan 29, 2018 | Canon Office Equipment & Supplies
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    The printer keeps telling me it's out of paper, which it isn't
    1> Open the sheet feeder cover and pull out the paper support.
    Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
    Pinch and slide the paper guide to the paper's left side.
    Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
    Pull down the paper output tray supporting with both hands.
    Pull out the extension completely.
    Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
    Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
    If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
    Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    HP C6180 stopped loading paper
    its due to the fact that paper you have loaded is being crashed inside the printer if you once again rotate the paper feeder stick and try it will work
    Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Will not pull paper into printer...half the time
    What sort of paper are you using? What sort of volume has the machine done? Have you ever had a jam and pulled the paper back out through the auto sheet feeder instead of feeding it through the exit rollers?
    Nov 12, 2008 | Epson Stylus Photo R300 InkJet Printer
    Paper source
    I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
    I really suspect a program is controlling this from the computer.
    To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
    The Set Factory Defaults option should fix most problems.
    Good Luck John Moser
    Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
    No Paper in Document Feeder
    I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
    May 23, 2008 | HP LaserJet 3055 All-In-One Printer
    Document feeder
    Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
    Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    HP Scanjet 7800 Pass-Through Scanner Logo
    120 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
