Question about Simac 4050 Il Gelatao Magnum 1 Quart Ice Cream Maker
Simac il gelataio machine
My Simac gelataio machine freezes but has suddenly stopped churning. Can this be repaired?
  • flash58 Sep 14, 2008
    its not freezing
  • afrigonia Dec 16, 2008
    I have a Simac 5000 it freezes but churns slower and slower each time and is only 2 months old
5 Suggested Answers
SOURCE: Simac - IL GELATAIO 1600 - The Ice Cream Maker Manual
See http://simac.com.au/index.php?option=com_content&task=view&id=21&Itemid=35 for GC-5000 manuals (one in Italian, with diagram). Not exactly the same thing, but looks pretty similar
Posted on Jan 29, 2009
  • 5603 Answers
SOURCE: Simac gelataio magnum plus machine does not get cold or freeze.
If the outer tub does not chill down, then the refrigeration is gone. CHECK that the airflow from the vents is active and free of obstruction.
If the tub starts to chill but the product tub doesn't get cold enough, you may have forgotten to put the Gin or suitable alcohol transfer medium in the outer tub.
Posted on Nov 09, 2009
SOURCE: need new blade from Il Gelataio ice cream machine
Hi i needed new blades to for my il gelataio machine have you found what your looking for , so maby you can tell me where i can get some new blades
Posted on Apr 28, 2010
alicantecoli
  • 22026 Answers
SOURCE: I am trying to repair
some of these machines are just not worth repairing at times as the problem is spare parts ,now if it was a carpagarne or however its spelt then parts are available from italy direct from the factory but this machine i have never heard off ,if you cannot locate parts from the internet then chances are they are not available ,the bearings are not a problem as a auto factor will most likely have them or a timkin agent will have equilivent ,a engineering shop can and should be able to re manufacture parts in stainless for the machine if their willing and able .but i do know these soft ice cream machines cost a arm and a leg and i dont know why
Posted on Nov 30, 2010
SOURCE: I have an old Simac Il Gelataio Super. I believe
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Posted on Jan 20, 2011
What causes the simac il gelataio to quit churning?
If you give the paddle a nudge, will it start ? If so most likely the big capacitor inside the machine. This capacitor will kick start the motor. If it is gone, the motor does not get enough power to get going. It is easy to replace once you have the cover off and should cost around $7.
Jun 30, 2014 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
What is causing the grinding noise with my Il Gelateo Super?
I have an old Simac as well , & the same trouble , grinding in a surging sound,, we opened the trhtings, the moto is good, but the base has been broken . It looks like a star shaped cage for the motor, not centralized , causeign the gear to crack & eventually to go. I am looking for the spare part as well. Will let you know . PS the newee version is 4050 il gelato Magnum. Mine is Il Gelato 2380.
Mar 14, 2012 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Simac gelataio magnum plus machine does not get cold or freeze. Motor works.
Nov 09, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Need repair manual for IL Gelataio 1600 ice cream
Best I can recommend is to go to www.delonghi-accessories.com. It's the site of a US distributor for Delonghi, which is the parent company of Simac, and it lists numbers for support.
You could try www.simac-vetrella.com if you speak Italian; or www.simac.com.au (I think this is a retailers site) might have parts, also.
Good luck.
kmaloy
http://grovebungalow.blogspot.com
Oct 16, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
I need the mixer blade
I need a Mixer Blade for my Simac IL Gelataio
Jul 06, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Parts
I have a Simac IL 1600 Gelataio Ice Cream Maker Machine I need the top the paddel, top , and screw
Mar 20, 2008 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Simac 4050 Il Gelatao Magnum 1 Quart Ice Cream Maker Logo
684 people viewed this question
Top Simac Ice Cream Makers Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Simac Ice Cream Maker Expert? Answer questions, earn points and help others
