Question about Akai Televison & Video
AKAI MODEL CT3216. SET COMES ON AT PLUG-IN. PIC COMES ON AT 10SEC. NO PIC PROBLEM. SET HAS POOR AUDIO WITH NO CONTROL FROM CUSTOMER CONTROLS. SET CUTS OFF IN ABOUT 15 SEC. LEAVE PLUGGED IN AND IT COMES BACK ON IN ABOUT 25 SEC. NO CONTROL FROM FRONT PANEL, THOUGH HIGH-PITCHED SQUEAL WHEN CHANNEL (PROGRAM) BUTTON IS DEPRESSED. I WONDER IF FRONT PANEL IS SOMEHOW INVOLVED, BUT NO MENU COMES ON SCREEN, AND NO OBVIOUS PROBLEM WITH PIC, AND NO DIALOG BOX ON SCREEN.
  • tvman550 Jul 11, 2008
    Earlier suggestions did not work. I think there was a bit of a misunderstanding: I did not mean I had trouble with the menu; I meant that the menu was not jumping on screen to indicate some trouble. There is no menu at all. Help.
  • 4,472 Answers
Akai are known as "throw away" tv's. Rather then waste your time with costly repairs. You would be much better served purchasing a new unit. I would recommend a name brand like sony, panasonic, hitachi. It will have a brand new factory warranty. Also the money you save on the cheaper tv's is not worth it because this is the end result. I would check out your local circuit city, or best buy. So you can shop around for a comparable unit.
Thanks,
Lee
Posted on Jul 11, 2008
  • 2,071 Answers
It seems problem is in microprocessor IC ,the function of this IC is controlling the system,that's command the menu on screen, volume indicator on the screen, no channel program on the screen and cannot control the control panel button and to the audio also,.
First to do is to checked the all parts sorrounding or associated to this IC,for leaky or dry capacitor ,change value resistor or open and shorted or open transistor,and checked also the solder joint for crack ,brittle or cold. If all of this are in good condition then i decided that microprocessor IC is depected, change that IC so the performance will be better again..or find a technician to do repair for you in order to avoid high voltage shock....
Posted on Jul 03, 2008
  • LORETO LACARON
    LORETO LACARON Jul 07, 2008
    Akai MODEL CT3216
    We just had the same problem.
    Picture-only went out for days and only returned in flashes. One mechanic
    over the phone said it likely was the power supply. Replace tv because it's
    too expensive to replace the power supply, he said. 2nd mechanic on phone said
    it likely was the bulb. Replace the tv because it's too expensive to replace
    a bulb and Akai is a lousy company from which to get parts. Third guy came
    over to look at it. Miraculously, the tv picture came on when he (only)
    turned it on, and hasn't gone off since. If it happens again, he suggested,
    unplug the power cord for 20 minutes--that's the black cord on the left side
    of the rear panel--left, assuming you're facing the TV screen front-on. Like
    a computer, he says, sometimes these things just need to be rebooted. It's
    not the power supply, he said. Otherwise, we'd have no picture OR sound. It's
    not the bulb, he said. Otherwise, we wouldn't get flashes of picture. Hope
    this helps somebody save money, and experience the joy we just experienced
    this week when we learned we didn't have to replace our 1 1/2-year-old LCD
    TV. In the meantime, we're keeping our fingers crossed!
  • 983 Answers
There may be some problem in the remote control board inside ..
either something is not connected or some thing has it burned out like capacitor ....
so you are not able to see the menu .....
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 11, 2008
    ok then try hard reset
    if it will not jump then try giving reset this will solve your problem ....
    & check is there any problem in remote ...
    check the batteries ... try replacing the batteries of the remote ...
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Akai convergence problems
Akai is Samsung--you can try with original remote to adjust in customer menu--
This can be a do it yourself repair= need to be able to get at the two chips etc and be able to solder etc==
MODEL NUMBER?
Your set will have two of them with either stk-392-040 or -020 on them.
Apr 15, 2012 | Akai Televison & Video
Akai projector double pic
If picture looks 3d etc it may be a convergence problem. What is model number of the set? Akai is a name owned by Samsung who uses it for some sets.
Typical convergence problem
Apr 02, 2012 | Akai Televison & Video
R tv akai pt4298hdxj/smsmanual
Check for bad connections on your yoke plugs. Each pic tube has its own yoke and will go to the main pc board, It will be a 4 wire plug w red, blue, etc. Two for vertical two for horizontal.
Nov 11, 2011 | Televison & Video
Poor sound cqality on a Samsung DLP TV
If you are receving your HD via a cablebox, check the volume and audio settings in the box's menu. Some boxes have internal volume controls. If the level coming out of the box is below a certain level, you may experience low or poor sound quality. You can also check the audio settings to assure that they are set to the original settings.
michtech
Feb 19, 2009 | Televison & Video
Need a remote for a pt5598hdix akai tv
Here's a link to order the original Akai remote control for this model (PT5598HDIX) from a major parts distributor:
Akai PT5598HDIX Replacement Part Remote Control
Also available in a cheaper version made by Samsung (which makes parts for Akai units) below:
Samsung PT5598HDIX Replacement Part Remote Control
Feb 15, 2009 | Akai PT4298HD Rear Projection Television
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
Proscan (old)PS35652 need code for Cable remote....one code will
tru going a google search for your brand and model # then type in remote or try this place to find the model # of your remote then do a google and ebay search for it
http://www.electronicadventure.us/Merchant2/merchant.mvc?Screen=SFNT
Mar 29, 2008 | Akai PT4298HD Rear Projection Television
AKAI FIX
My set had the same issue with the picture and burning smell. On my set, I just removed the cap and the set works great without it.
Aug 08, 2007 | Akai PT4799HD Rear Projection Television
1 thick Vertical line and many small diagnaol lines across screen ? I tried to reset TV a number of times and tried the Perfect Focus with no help. Akai's only service center in manhattan DO NOT service...
Are you kidding/?? Customer service told you to find your own repair shop.? Its time to sit down and write a letter to the main headqaurters that would be listed in your owners manual . MAN their not suppose to say stuff like that to customers. I would address it attention to the president of Akai and send a copy to the BBB and the consumer affairs as a company is suppose to provide parts and service for there products for at least three to five years ., It used to be seven! You didnt say how this happened or if there was sound or any video on the screen. I might be able to lead you thru some diagnosie,BUT these sets do not have any user serviceable parts inside and can hold several differant hi voltages in the set ,even if its unplugged or off . Please if you can send a picture of your problem But as i said if your not a tech its very dangerous to tinker with these set! Good Luck
Jun 10, 2006 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Akai Televison & Video Experts
Dave Naylor
Dave Naylor
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
