Question about Xerox 5665 Copier
Xerox 5665 beeping for all functions
Is there a way to turn off the beeps - it beeps three times for printing - beeps everytime you touch a button or select off the select screen. It is very annoying since I sit near it!
  • angelesta Mar 30, 2009
    I agree - this stupid machine doesn't stop BEEPING! please tell me if there is a way to turn it off, it's giving me a headache!!!!
  1. Press the [Log In / Out] button on the left side of the Control Panel. The System Administrator Login screen will be displayed.
  2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE: The System Administrator Login ID and UserID is '11111' by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
  3. Select the [System Settings] button twice. The System Settings screen will be displayed.
  4. Select the [Common Settings] button. The Common Settings screen will be displayed.
  5. Select the [Audio Tones] button.
  6. Select the required option from the list, and then select the [Change Settings] button.
  7. Select the [Save] button to save the settings.
  8. Select the [Close] button several times, and then select the [Exit] button to exit.
Posted on Aug 31, 2009
  • 239 Answers
On the menu, select "tools", I believe it is either four "1's" you need to type for the password, or four "4's". Once you are in the machine preset selections, somewhere there in the presets you might find "Beep" on or off.
If you cannot find it in there, it will be in the diagnostics section. The service repair person is the one to enter in it and change the machine configurations. Only a trained person with the service manual should enter this section.
Posted on Oct 16, 2009
  • Gilbert Gonzalez Oct 16, 2009
    The Xerox machine is fine. Office equipment are like a cars, and cars, they do get old.
    Not having a service manual, especially a former repar person, one has a tendency to not remember all the codes on every machine, this is why a operator and service manual comes in handy.
    If you enter the 5 or 6 "1's, and it not work after 3 times, the machine will lock up. Go out of the menu and try going back in after waiting for a while. If not, turn off the machine for at least 10 seconds and turn it on again.
    Good luck.
Get rid of it and buy an oce printer. xerox service sucks and i doubt anyone from xerox would ever help you unless there is a sale in it for them
Posted on Jul 03, 2008
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
Tip
How to fix a PS3 when it's frozen at startup
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step1
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
· Step 2
Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
· Step 3
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
· Step 4
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
· Step 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a05/kb/9c/fix-ps3-it_s-frozen-startup-1.5-800X800.jpg'); }); Connect controller to PS3 screen.
You will then see this screen.
· Step 6
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
· Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/a05/kb/9c/fix-ps3-it_s-frozen-startup-1.7-800X800.jpg'); }); Safe Mode options screen.
· Step 8
Select option number 3, (Restore File System). Then select yes to perform step.
· Step 9
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
· Step 10
First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
Hi.my name is kereshen .i have a new xerox workcenter 5222 printer. i just loaded the driver.and when i go to print the printer just beeps and does not print at all.im useing windows xp sp2.can you help...
You can turn off the beeps from the admin mode. press the little button with the key on. The default logon id is 11111 then just turn off all the beeps in the tools menu. Pity the ones who have to sit next to one of these things, it's like a supermarket till. beep beep beep beep grr.
Oct 28, 2010 | Office Equipment & Supplies
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
10,686 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
