Question about Tekram /Areca PCI to Serial ATA controller, up to 4 Channels, 150MB/sec (EJTR824)
Tekram TR-824: cannot update BIOS
Dears!
I have Tekram TR-824 adapter working fine with 2*250Gb SATA WD HDDs. I've bought 2*750Gb SATA WD drives. Both can be recognized by on-motherboard SATA adapter but each one o fthem (and both together) cause hang-up of TR-824 on computer boot-up. I thought the old BIOS firmware version I have (5.0.2.4) is the reason and tried to update the BIOS. No one program I tried can help (including flash82x.exe from disk).
Chip: Sil 3114CTU
Flash: WinBond w39L040P-70B
No one program can determine the flash memory type, I guess.
Can enybody help with the flashing program or with the overal situation solution?
Thanks in advance,
Eugene Polyan aka MEPhIzik
Download from siliconimage.com "UpdFlash" and
Posted on Sep 02, 2010
  • z-e-s Sep 02, 2010
    new bios [r5403.bin].
    • Download the latest copy of the FreeDOS kernel from internet,[sourceforge.net]
    • Unpack the archive, change directories to where you unzipped it, insert a formatted diskette in a: drive, and then run the install batch file from there. That should make a bootable floppy drive in “a:”
    • Copy the UpdFlash.exe program file and BIOS binary[r5403.bin] file to “a:”
    • Boot from the floppy, run UpdFlash to load flash memory with BIOS binary code
    Under FreeDOS select "2. AMD 29F040B 4Mb compatible" (for WINBOND 39L040).
    Said works.
My pc is not detect MJA2160BH
You are talking about a 160gb Fuji SATA Drive. (5400rpm 2.5")
There's a couple of things here...
Assuming you've removed the old drive, and simply plugged this one in..
SATA drives are "standard"-- kind of like USB. They WORK, or they don't. If your drive isn't recognized by BIOS, then its either connected wrong (VERY HARD, connections have directional connnections) or it's simply bad.
If your machine does NOT see the device in BIOS (if it does..insert your OS CD and install the OS)... then it's simply bad.
Return it..get another..and if I may add $.02... 160bg SATA vs price of say... 750gb sata...is next to nothing..go bigger.
Oct 16, 2012 | Fujitsu - MJA2160BH 160 GB SATA Hard Drive
In RAID10 4HDDs samsung HD103UJ 3 HDDs failed at the same time
Sounds about like a TDL4 malware infection, or perhaps the BAD BIOS infection!
Apr 26, 2017 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Computers & Internet
Installing an ide in a vista sata
Some of the laptop/s and desktop/s with IDE hard drive is not being supported by the Windows Vista. No matter you did already updated the BIOS still it will not fix the issue. If I we're you, have another SATA drive not and IDE one.Thank you.
Oct 05, 2009 | Computers & Internet
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
Installing 750GB SATA on Asus A8N-E Mobo
Hello there.
I would not update the BIOS unless you are experiencing any problems. Try installing the new hardware first and then if you do experience problems, think about upgrading the BIOS. The latest version is 1013 FYI.
The new hardware should be supported without a BIOS update, as long as you have Service Pack 2 in Windows XP or above then all your 750GB will be shown. As for the memory you should see it list the new size in the POST screen before Windows even loads, or inside Windows.
If you do have problems, then please post back and we can help.
Hope this helps.
Jul 19, 2008 | ASUS A8N-E Motherboard
Ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Mar 30, 2008 | Computers & Internet
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me chepu_456@yahoo.co.in
Feb 21, 2008 | ASUS K8V-MX Motherboard
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
NetRAID-2M hangs out while initializing HDDs
Here's a link to the fireware update tool you need to do the flash: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=329290&prodSeriesId=65146&swItem=ns-9915-1&prodNameId=19319&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0 As for never getting the chance to boot from the floppy drive to update the drives, try using the ServeRAID controller just to flash the drives then put the NetRAID-2M controller back in.
Jan 30, 2006 | HP NetRAID-2M SCSI Controller
Tekram /Areca PCI to Serial ATA controller, up to 4 Channels, 150MB/sec (EJTR824) Logo
408 people viewed this question
Top Tekram Computers & Internet Experts
John Anderson
John Anderson
Robert Graf
Bill Boyd
Are you a Tekram Computer and Internet Expert? Answer questions, earn points and help others
