Question about Canon MX300 Office All-In-One Printer
Switching between color and black and white
How do you switch from color printing to black and white printing? My canon mx300 seems to only print using the color cartridge. If I take it out, it won't print even though I have a full black and white cartridge. I have an Apple iMac with Leopard. Can't find anything on the iMac that allows me to choose the cartridge. Can't find anything in my Canon instruction manual that discusses this either. I prefer black and white as default as opposed to color. Help me please!
  • Anonymous Mar 18, 2014
    i want to print a color pdf file in black and white sending from a mac. How do you delete the color when printing?
  • Anonymous Mar 31, 2014
    Full print-out of details when I print a Word document. Have turned it off in machine but still defaults back.
  • 2,039 Answers
Go here. In the search box in the center of the screen, type "print with black ink only" and click Search. Choose the appropriate link, and you will get instructions for printing from either Windows or Mac.
Posted on Jul 03, 2008
Canon MX330
sometime my printer does the same, print something and see how the black color is, if it is printing or it is the color ink that needs to replace also. i just keep printing until the ink get real light then i change them.
Jul 10, 2014 | Canon MX300 Office All-In-One Printer
How do you switch the ink to print only black on the canon mx300?
You need to change the settings from the printer preferences from your system.
For windows 7 Goto Control Panel>Devices & Printers> Right click on the printers prefrences & under tab of paper layout/quality select black & white
For windows XP Goto Control Panel >Printers>Right click on the printer icon & select printer properties from their color management
Oct 24, 2010 | Canon PIXMA MX300 All-in-One Printer
My printers color ink cartrige has run out. I switched to printing w/ black only, but the printer still displays the alert and will not start printing. The model is a canon mx 300
All the Canon machines are that way, you won't be able to print unless you replace the color cartridge as well. There is not a way even in service mode to bypass this condition, they want you to buy more ink.
Feb 01, 2010 | Canon MX300 Office All-In-One Printer
Mx300 not printing properly
Go to printer properties dialog box
Control panel>prniters> select your printer
select printer preferences
Check whether grayscale printing is selected.
If so uncheck it.
Hope this helped
Jan 09, 2010 | Canon MX300 Office All-In-One Printer
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
I HAVE MX 300 PRINTER IN WHICH THE COLOUR CARTRIDGE FINSHES OFF QUICKLY THOUGH I DO NOT USE COLOUR PRINTING PLEASE ADVISE
You can goto printer settings and choose black and white printing only, it will be there in one of the options of your printer.If your printer has only one cartage Color, then when you rpint in black and white you are using all 3 colors to create this black and white, nothing much you can do there. But if your printer has two cartages 1 black&white, and 1 color then tell it in settings to print only black and white, hope this helps
Nov 29, 2009 | Canon MX300 Office All-In-One Printer
Canon mx300 not printing
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon MX300 Office All-In-One Printer
How can i print in black and white
There should be an option in the Printer setup. When you print, and the Print dialog comes up, click Properties. Either in the Basic or Advanced tabs you should find an option stating "Monochrome print" instead of "color print". This instructs the printer to only use the black ink cartridge.
Oct 30, 2009 | Canon MX300 Office All-In-One Printer
Black and white printing on Canon MX 310
there is in adjusting the seal the printer bookmark, seal grayscal stile. Search for in adjustment before printing
Apr 24, 2009 | Office Equipment & Supplies
Printing from 4050 from Internet Explorer 7
try installing mozilla as it could be an issue with IE7
install this its free
http://www.mozilla.com/en-US/
Jun 09, 2008 | HP LaserJet 4050t Printer
Canon MX300 Office All-In-One Printer Logo
1,331 people viewed this question
old marine
old marine
