Question about Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 - what do I need to adapt hard disk to fit this laptop?
Hi and thanks for any help. I have a Travelstar 80 GB ATA drive that needs some type of adapter for the pins to fit into the hard drive port in the laptop drive bay. The port in the computer is smaller and centered, whereas the hard drive connection pins are wider spaced. I can't find a specific part to adapt one to the other. I can buy a 'drive caddy', but that is just the metal housing for the drive itself. I appreciate your time on this.
    Genius:
  • 2,028 Answers
That is a very interesting problem. I couldn't find anything on a hard drive connector. The only thing I found is on Ebay and they call it a hard drive cage. They are very specific as to it not being the caddy. There's no pic, but here's the link, maybe you can contact him to send a pic. It could be what you need???
http://cgi.ebay.com/Acer-Aspire-5100-Hard-Drive-Cage_W0QQitemZ130160071476QQihZ003QQcategoryZ16145QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Posted on Jul 03, 2008
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
I had travelstar 5k250 2'5 sata hdd in my laptop acer aspire 2920 and need to replace it now due to damage but can not get same one which one will replace it
use a good quality drive such as samsung/toshiba etc.
it just need to have the 2.5 format and sata connections be fast enough and big enough for all you stuff.
most laptop drives are 4200 if you are not doing anything with graphics or video then, it might be ok. professional users will buy 7200 speed drives
Hope this helps
Thanks for using FixYa
Aug 12, 2010 | Hitachi Travelstar 5K250 HTS542525K9A300...
I want to know what type of hard drive I can use in an Aspire 3680.
The specs show an 80 GB hard drive. Probably ATA (you can tell by looking at the end of the drive--if it has a bunch of pins on it, it's ATA. If there are only two connectors, it's a SATA.
You can probably go to 150 GB or so. Don't go too large or you'll be bound to have problems. Mostly there are 120 GB and larger drives out there now. They don't make 80 GB any more.
Dec 18, 2009 | Computers & Internet
Replacing laptop HD
Spend the money and go with a 7200 rpm drive, 160, 320, or 250 gb hard drives are all under 100 bucks these days.
Oct 03, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Unusable drive with bad sectors in drives service area
I would temporarily attach it directly to your laptop and go into recovery console and do a chkdsk /r on that drive
see if that helps, if not then there are things you can do.
post back for more info
May 17, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Noisy laptop computer
If your looking for a tool to diagnose the hard drive you need to go to the hard drive manufacturers website
Eg for a hitachi/travelstar drive you can get a copy of DFT (drive fitness test) from hitachi site
You can create the install disks from acers in built recovery console.....typically takes about 2 dvds
Nov 22, 2008 | Acer Aspire 3000 Notebook
I need this driver please
TRY TO CHANGE THIS IN SET UP
Nov 08, 2008 | Computers & Internet
Acer 5100 PC
Pretty simple. You'll just need to determine whether the system uses SATA or IDE for the hard drive interface. Many machines manufactured in the past couple of years use SATA, but any 2.5" drive will be compatible providing you have the correct interface. ATA drives for laptops are generally called PATA and if it's such an interface any ATA-6 drive will be compatible.
You might need a SATA driver for the Vista installation, so bear that in mind. You'd specify additional drivers during the setup process.
Good luck.
Ben
Sep 17, 2008 | Acer Aspire 5100-3357 Notebook
Acer Aspire 5100-5033 Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
