Question about Canon Cameras
I wonder if i could record a footage from my camera and then hook it up to my vcr to place the footage onto a tape
  • kymie Jul 03, 2008
    av cable is that the same cord that connects to the computer to download pic to your computer?
    THANK YOU I WILL TRY IT OUT!! WISH ME LUCK!!!
  • 477 Answers
Yes you can you should have a AV cable for you camera that will plug up to a VCR.
Posted on Jul 03, 2008
  • Mike Johnson
    Mike Johnson Jul 03, 2008
    no the av cable has 2 rca jack on one side and eather a thing that looks like a head phone jave or a diffrent type connector on the other it might also plug into the same connector as your Computer cable.
I own a Panasonic 3ccd nvgs mini dv i was shooting some footage...tape got horizontal lines on it... i really really need that tape... can it be fixed?...thx a milion
Sounds like dirty heads .
If the lines are recorded onto the tape, probaly not.
Try a head cleaning tape in the camera or use another playback device.
If the lines are recorded onto the tape then track down someone with a TBC (timebase corrector) and pipe the signal through that and record to another tape.
Apr 13, 2011 | Panasonic NVGS-200 DV Camcorder 3 CCD 2.32...
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
HVX200 shot footage - viewing footage on consumer grade camera
You can only view hd footage on hd devices. so if you recorded hd footage onto a tape, you will not be able to view it on a standard def camera, ie the dvx100b. The footage should not be harmed. Now if you are trying to view via p2 card over the firewire, whole new scenario.
Apr 12, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Sony HDR-HC3 camera won't connect in HD mode in iMovie HD or FCP HD
What software are you using to capture the HD footage? Are you using the supplied software, or another package. It is likely that you have a software incompatibility. i.e. windows will recognise DV natively, but HDV requires specific codecs and software installed on your PC.
Aug 30, 2007 | Sony Handycam HDR-HC3 HDV Digital...
How do I transfer my camcorders recordings from HI8 tape to a computer or DVD?
Do you have another video camera that will hook up to your computer? In the past, I've connected my old Hi-8 to my Mini DV, recorded the footage from the Hi-8 to the Mini DV and then digitized on the computer from the Mini DV. You will however need some video software like iMovie for this solution.
You can also, hook the Hi-8 camera up to a VCR or TV using the appropriate cable and view it that way.
Feb 09, 2007 | Samsung VP-L800U Camcorder
No playback, only blue screen!
try again after cleaning the video head. i think you will solve the problem.
Nov 02, 2006 | Panasonic PV-GS300 Mini DV Digital...
Cameras Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
