Computers & Internet Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pinout for front panel connector (on switch / power LED / HDD LED)
Anonymous
Level 2:
New Friend:
  • Expert 82 Answers
  • Posted on Dec 20, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
82
Questions
Helped
20287
Points
245
The molex connector
1helpful
2answers
Transferring motherboard from Gateway SX2801-07E to another case. How do I connect the motherboard front panel headers?
  1. Identify the headers: Locate the front panel headers on the new case and on the motherboard. Make sure that you have identified the correct headers and that they are compatible with each other.
  2. Check the pinout: Refer to the manual for the new case to determine the pinout for the front panel headers. Make sure that it matches the pinout listed for the motherboard, as mentioned above.
  3. Connect the wires: Use the pinout information to connect the wires from the new case to the appropriate pins on the motherboard. Make sure that each wire is securely connected and that there are no loose wires that could cause a short circuit.
  4. Connect the HDD LED: The HDD LED can be connected to pins 13 and 14 of the front header (LEDH1).
  5. Connect the power LED: The power LED can be connected to pins 3 and 4 of the front header (LEDH1).
  6. Connect the reset switch: The reset switch can be connected to pins 7 and 8 of the front header (LEDH1).
  7. Connect the power switch: The power switch can be connected to pins 10 and 11 of the front header (LEDH1).
Make sure that you connect the wires correctly and securely, as an incorrect connection can cause damage to the motherboard or the front panel components.
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
2helpful
2answers
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
2helpful
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
4helpful
2answers
Simple pinout help
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
15helpful
IBM Netvista MB 49p1599 Front Panel Pinout
1 pw sw
2 pw sw
3 rst
4 rst
5 - pw led
6+ pw led
7+ hdd led
8 - hdd led
<== left 1. . . . . .8
ATX connector ==> right
2helpful
PC Chips M955G Motherboard Front Panel Pinout
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Grand Canyon Tech
Grand Canyon Tech
