Question about Panasonic PT-LB10VU Multimedia Projector
Replacement lamp not working
The lamp was replaced properly secured and starts greeen light solid then starts blinking then later becomes red and in the end lamp light control turns on red --i need to reset the bord to make it work?how?
  • 4 more comments
  • edwardp33 Aug 15, 2008
    When I power the unit on the standby light flashes green, the fan turns on and after about a minute the standby light turns orange and teh lamp light flashes red. This unit has done this with the current bulb and a brand new bulb.
  • gjackson911 Aug 19, 2008
    I have had the exact same problem. I replaced the bulb, I get a green flasher for 1- 2 minutes, then is shuts down and the red "LAMP" indicator comes on.
  • jwm507 Aug 26, 2008
    Same problem with a Panasonic PT-LB10NTU properly replace the bulb with a new (very expensive) bulb and the green light and fan comes on for a minute or so then then the red light starts flashing.
  • j4oud Nov 21, 2008
    I have the same problem with the PT-LB10VE version, tried two projectors and a new replacement bulb
  • Charlie Wolff Feb 16, 2009
    Bought my PT-LB10VU brand new in early 2005 and used it once. It sat in a cabinet until February 2009. We'd forgotten we had it, actually. But when we fired it up, it flashes green, then to steady green but no light, then repeats flashing green, then lamp indicator flashes red! Thinking maybe the bulb (with less than 10 hours on the machine) might have been jostled or something, we bought a very expensive replacement. Same problem. Hasn't anybody figured this out yet? How could power supply or ballast go bad with so few hours on the machine?
    OK...can anyone tell me how I can test a thermosensor? The repair manual has taken me to this step, but I'm stumped at this point.
It seems there could be a number of problems causing this. For the PT-LB10 series, there's a service manual at
http://owa.mellafeysalas.cl/dscgi/ds.py/Get/File-3457/PT-LB10_SvcMnls.pdf
You'll need to be handy with electronics, or know someone who is...
Posted on Feb 16, 2009
Replaced bulb for a PT-50LC14...worked great til I turned TV on then click off 25 seconds after. 3 hrs later...turned it on and nothing except 8 green blinks on power button then solid red(shuts off) No...
Remove lamp to see if it was not inserted correctly (easy mistake to make) and also make sure door on lamp was closed securely--a safety lever there will prevent set from working if door not engaging the lever.
Jun 17, 2012 | Televison & Video
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
Apr 20, 2012 | Televison & Video
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
I HAVE A SONY KDS-60A2000 WONT TURN ON. RED LIGHT BLINKS THREE TIMES. TRIED NEW BULB. NO DIFFERENCE
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
Mar 11, 2011 | Sony KDS-60A2000 60" HDTV
I put in a new light engine and a new bulb and no picture
U check the ballast?Replaced it might solved ur problems.
Apr 04, 2010 | Toshiba 62HM95 62" HDTV
Just replaced bulb and the tv still does not work? the green light flashes 9 times and the red light is solid
Howdy;
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Open Questions:
Panasonic PT-LB10VU Multimedia Projector Logo
997 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
