Question about GE DBSR453EBWW Electric Dryer
No power to dryer
We have a GE DBSR453EB3WW dryer and I loaded clothes in it yesterday and turned it on. I just do these chores automatically so can't tell you if the light came on or if the dryer came on when I turned it on but I feel certain both were working as normal or I would have surely noticed the change. Anyway, my husband came home, was going to empty the dryer and throw another load in, but the clothes were still damp and no light came on when he opened the door. We've searched high and low for the owner's manual to no avail. My husband seems to think a wire in our wiring to the house (where he gets these ideas is beyond me) has come loose and he plans to check into this when he gets home. I'm scared silly. We don't have another appiance to plug into this 220 outlet to tell for certain if it is the dryer or the power to the dryer. Any suggestions before my husband fries himself this evening? I mean, like how likely is it a loose wire? He's checked breakers (one is labeled dryer, but we've only lived here a little over a year and have never needed to check the dryer before so since the breaker switch isn't flipped to 'off' we assume it's working properly, but can't tell since we don't have anything else to plug into that outlet). Is it likely something to do with the dryer? If so, what? I mean, it's so weird that the light isn't even coming on and I don't think it's just burned out because we just replaced the bulb about a month ago and the dryer was working fine while the bulb was burned out.
  • DEWPOT Feb 01, 2009
    GE DWSR483EB1WW ELECTRIC DRY, WONT START, LIGHT COMES ON, WHAT CAN I DO TO GET IT TO WORK.
  • 54 Answers
If you go to lowes you can purchase a pen type voltage tester cheap. Insert the tip into the 2 long prongs they are the hot wires. The L shaped one is the netural. You might unplug the dryer and remove the cover where the cord goes in the dryer. Check and make sure the wires are tight where they attach to the terminal block as alot of times the installer does not tighten them.
Posted on Jul 04, 2008
    Novelist:
  • 177 Answers
Does your Husband have a meter to check voltage? if not any good hardware store, Sears or Radioshack will sell you a meter for checking voltage at the outlet. I cant give him a lesson on electricity he has to feel comfortable with that.
I have witnessed many dryer installations where they blame the dryer and come to find out its the house wiring, oh bye the way here is my bill and you need to call an Electrician to replace this and he will bill you also. My service stops at the power cord! Make sure when your husband checks for loose wires he has the power off, if you are not sure of the correct breaker turn the main off. then he can check for all the loose wires and he wont fry himself.
I would also ask that you turn the breaker off and on several times to reset it, the dryer could still run but not heat if one side doesnt work.
Let me know if you have any further questions.
Posted on Jul 03, 2008
Does m G E Dryer have a reset button?
No, but if the belt breaks the pulley will actuate the motor kill switch will wont the machine turn on. Thats where I would start.
Aug 24, 2012 | GE Dryers
Drum on GE dryer is making squishy noise model-dbsr453eb3ww serial-tl713439a the noise happen when on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 20, 2011 | GE DWSR463EG Electric Dryer
GE dryer dbsr453eb3ww making very loud squealing noise. Could it be belt? How do you access the motor?
You probably have worn front bearing slides, 316 and 313 in the diagram. You may also have a worn rear bearing 3106 in diagram. Slide putting knife between front panel and top near edges to release clips to gain acess to internals.
Oct 01, 2010 | GE DBSR453EBWW Electric Dryer
Squealing dryer
it may also be a bearing, you have to remove the outer cover to access the workings
Aug 17, 2009 | GE DBXR463EBWW Electric Dryer
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer drum doesn't sart rolling when it is turned on.
It is not using the start winding in the motor. You might be able to remove the end bell and clean the switch?
Apr 24, 2009 | GE DBSR453EBWW Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryer dbsr453eb3ww
sounds like electric heating element issue to me. Your gas dryer doesn't have electric heating elements which might explain your problem
Jun 26, 2008 | GE DBXR463EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
225 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
