Question about Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC
Almost loaded but wont start
Ive been havin this problem for months and it still isnt fixed. ive tried uninstalling and re-installing and restarted it but it wont work. then ive tried usin the internet 2 fix it and nothin has happened. does anyone know any other solutions 2 mi problem?
  • 326 Answers
After you uninstall the game try finding the directory it was installed to and delete the folder, try installing again.
might help
Posted on Jul 03, 2008
My acer aspire one wont come off the 'Setup is starting services' screen. After a while a message will come up saying it cant complete because windows isnt installed. Then it restarts the laptop and does...
The error is in your Operating System or your last Installed Application.
you should do this first.
1.Try boot the computer in Last known good configuration to go back to the earlier configuration when it worked fine.
Keep tapping f8 key when you restart the computer, from the advanced options, select Last known good configuration .
2. Reformat your PC this was the best Solution
Aug 21, 2013 | Acer Aspire Computers & Internet
Remove searchnu.com/406 from google chrome
searchnu.com is a sneaky search engine. it will attempt to take over the search engine you are using now. this happens if you download links or applications that your PC isnt familiar.They usually cause problems right after you install them so you must uninstall them. Ive had this same search engine do the same thing to me. You also need to uninstall google chrome then reinstall along with all your other downloaded search engines. but do not do this with Eexplorer search engine. after you install google chrome with all the other search engines you uninstalled, dont sign in to them for about 3 months. then there is a good chance you wont get them back unless you try to download something your PC isnt familiar with or if the screen pops up and says "this file may harm your computer". your lucky if you didnt get a virus along with it cause that will usually happen. Just be careful what you download.
Apr 21, 2013 | Microsoft Windows XP Professional With...
My Kodak esp 5210 is fine but my pc cant find it.
Go to device manager. To do this, right click on my computer icon and click on manage. In the drop down menu, you will see device manager. Click on it and uninstall the printer drivers there by going to printers tab. Your printer will be shown there. Right click on it and uninstall the drivers. Next, restart the computer and try installing the drivers.
If this does not help, ask experts from http://www.vtechsquad.com/ ,to get technical support.
Feb 13, 2013 | Kodak Esp 5210 All-in-one Inkjet Printer
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
Repeated message "windows cannot load OmnisuperCam" Followed instructions and reinstalled carefully twice. Photo Impression 6 loads and is active. OVT does not appear in control panel 'scanner and camers'
Hi.
This often happens because Image Copier installation must be done in exact order as described in the instruction manual. To fix the problem you need to uninstall and reinstall everything back in right order.Also remember to restart the system when required.
  1. Unplug the image copier
  2. Uninstall the driver (remove from installed scanners and remove driver files).
  3. Uninstall PhotoImpression6
  4. Restart your computer.
  5. Install the driver,.
  6. Restart computer
  7. Reinstall PhotoImpression6 software.
During installation ensure that you authorize the system changes when asked. If possible disable any security software.
If that does not fix the problem, then the registry must be cleaned of any entry related to the scanner software. This is rather difficult to be done manual. You can try doing a system restore to a recent date before the problem started after uninstalling everything, and then uninstalling again if needed (application and scanner are there after SR), and finally reinstalling everything in order. If that does not work you can try a registry cleaner or reinstall the system.
Here a copy of the manual.
Jun 22, 2010 | Computers & Internet
Webcam not wrokin , shows a code 10 error
in add/remove uninstall cam then unplug it from pc in device manager uninstall driver then restart and run software do not plug cam in until prompted or after restart
let me know
Feb 15, 2009 | HP Computers & Internet
Computer Keeps restarting
start in safe mode, and uninstall
Jan 06, 2008 | Dell Dimension 8200 PC Desktop
Help: Put 360 games in console, wont load says "put in xbox 360" no red lights?
Ok I had the same problem try this if this doesn't solve your problem call Microsoft.
First, Unplug everything including harddrive.
Next, Wait thirty seconds.
Then, Plug everything even harddrive.
Finally, Try it out see if it works. If it doesn't call Microsoft.
1800-4MYXBOX / 1800-4699869
Dec 21, 2007 | Microsoft Xbox 360 Console
Ubi Soft Petz: Dogz 5 and Catz 5 Compilation (008888682295) for PC Logo
76 people viewed this question
Top Ubi Soft Computers & Internet Experts
Piyal Perera
Piyal Perera
Pavel Pranovich
Pavel Pranovich
tony wahlman
tony wahlman
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
