Samsung HL-T5676S Television Logo
Posted on Dec 20, 2010
My tv does not turn on. When power button is pushed it goes from red standby light to green power light but nothing happens and then it repeats this a couple times on its own. Then stops and all three lights blink and thats the way it stays. No picture no sound.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
334
Points
Sounds like the bulb needs to be changed
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Polaroid 4011-tlxb. Power to tv and it was turning from red to green light when you press power button but no picture. Pressing any buttons on tv or remote and nothing was happening. Replaced power supply...
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2helpful
No picture but have green light
  1. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  2. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
2answers
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
